Mon, Feb 10, 12:51 PM CST
Subject: SpotLights C'm On!
Robo2010 ( ) posted Fri, 14 October 2005 at 11:02 AM · edited Mon, 10 February 2025 at 12:46 PM
I can not figure out, why these spotlights on the right (Arrow) will not turn on. I move em around, change the angle start/End, Dist Start/End, and I do not get any results. I move them as well, thinking maybe the mesh has something to do with it..(I dunno). I am trying to get em to work like the ones on the left, that are pointing on the wall on right. I need those lights on the right to point at the wall on the left. But I need them to turn on, so I can adjust.
ockham ( ) posted Fri, 14 October 2005 at 11:18 AM
Does the wall on the left show up at all? Even with ordinary (infinite) lights? Sometimes Poser 6 will show a surface as black regardless of lighting. In that case, checking "Normals Forward" in the Material room for that wall will usually make it show up.
My python page
My ShareCG freebies
Robo2010 ( ) posted Fri, 14 October 2005 at 1:09 PM
yeah..it does..I even moved the lights that are on the right..to the left side, and they still do not turn on.
Robo2010 ( ) posted Fri, 14 October 2005 at 1:23 PM
Ok..I delete the lights on the left. Now the lights on the right turn on. What gives?
mateo_sancarlos ( ) posted Fri, 14 October 2005 at 1:26 PM
Try turning off the lights on the left, add a ball prop, then move it around the lights on the right until it shows up, so you know where they're pointing.
stewer ( ) posted Fri, 14 October 2005 at 2:07 PM
Oh wait, this only the preview, right? Will they show up when rendered? OpenGL cards have a hardware limit of how many lights they can use, my card for example limited to 8 lights. They will still be there when rendered. To see them all in the preview, switch to SreeD instead of OpenGL, SreeD doesn't have a limit for the number of lights.
kuroyume0161 ( ) posted Fri, 14 October 2005 at 2:11 PM
My thoughts exactly, stewer. You will be hard pressed to find an OpenGL preview with more than 8 lights.
 -- Bjarne Stroustrup
ockham ( ) posted Fri, 14 October 2005 at 2:19 PM
Just for fun, I tried building a similar setup in P6. It seems to work OK, so I don't think you're running into a natural limit on number of opposing spotlights or whatever. Above is preview, below is render.
My python page
My ShareCG freebies
ockham ( ) posted Fri, 14 October 2005 at 2:23 PM
Hm. Guess my picture proves the point about the Open GL, doesn't it? (I'm so accustomed to lights not showing up correctly in preview that I didn't even see it as a problem....)
My python page
My ShareCG freebies
Robo2010 ( ) posted Fri, 14 October 2005 at 4:25 PM · edited Fri, 14 October 2005 at 4:27 PM
I do have it on SreeD. I guess my limit is 9 lights. And I have a total of 14 spotlights. I see them working now, after a render. Since I am not able to see the lights on the right in the preview. Positioning em, isn't going to be easy, even when using the shadow cam. I like how the lighting is shown on the roof (Top right). Trying to get it the same on Top left. Oh..I also like to use atmosphere (Volumetric lighting). I decided only to use 2 (Lower front) to give the dusty air look. Any suggestions?
Message edited on: 10/14/2005 16:27
Robo2010 ( ) posted Fri, 14 October 2005 at 5:03 PM
Ah..thats ok for the Volumetric lighting. I had to refresh my mind. I got it together. Will show a render when done.
Robo2010 ( ) posted Fri, 14 October 2005 at 6:32 PM
Did a render using the Volumetric lighting. Here is my results for now. Still adjusting.
xantor ( ) posted Fri, 14 October 2005 at 7:05 PM
It looks great so far.
KDoug ( ) posted Fri, 14 October 2005 at 8:54 PM
Lookin' good, Robo! I do feel like the bright area on the floor in front of the mech makes it look a little like it's floating, but that's my only real complaint.
