Sat, Feb 8, 9:05 AM CST
Subject: Some Liquids & Lights Issues
FranOnTheEdge ( ) posted Thu, 20 October 2005 at 11:31 AM ยท edited Sat, 08 February 2025 at 9:02 AM
Got a render here of glasses & a bottle on a table by a wall. What's worrying me are those almost photographic images of the glasses and their liquids on the table. To me they look too... good. Help?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
FranOnTheEdge ( ) posted Thu, 20 October 2005 at 11:33 AM
Here's the sky lab...
Fran's Freestuff
FranOnTheEdge ( ) posted Thu, 20 October 2005 at 11:36 AM
Oh and I just played with "DeepBlue" for the red wine and the glass texture is just "Glass Bubble1".
Fran's Freestuff
shinyary2 ( ) posted Thu, 20 October 2005 at 1:20 PM
One way is to turn on soft shadows. You can then set it to Premium at 4 RPP for your test renders. It's much faster that way than on regular AA when you soft shadows enabled. Also, you might try rendering the texture from the bird's eye orthographic view and using that as a height map, as in the demo pic. For the final product, I was too lazy to use soft shadows and wait for it to render (doesn't look too great at 4RPP lol). Hope this helps.
dadt ( ) posted Thu, 20 October 2005 at 1:55 PM
Fran-Just checked my settings again. The renders in the Wings forum were done on Premium setting with True Ambient on. This makes some difference.
danamo ( ) posted Thu, 20 October 2005 at 2:07 PM
I wonder if enabling blurry reflections might help too. @Shinyary2- I use the birds eye orthographic render a lot. I use a variation of the method you show here for making sand dunes, or waves. Works great!
FranOnTheEdge ( ) posted Thu, 20 October 2005 at 3:36 PM
shinyary2, what are where is 4RPP? Anything that cuts down on the time it takes for soft shadows! And shinyary2? Your render still looks too clear on that image projected onto the ground surface/wood/whatever.
Fran's Freestuff
AgentSmith ( ) posted Thu, 20 October 2005 at 4:01 PM
I vote for using soft shadows. It's the only way to make glass shadows like that look anywhere more realistsic. (in my experience), although the solution shinyary2 has given is the greatest thing you can do if you don't want to use the soft shadows. Very unfortunately, you are looking at a long render. AS
AgentSmith ( ) posted Thu, 20 October 2005 at 4:03 PM
If you go to your render options, this is what you will see for the 4 rpp (rays per pixel) AS
AgentSmith ( ) posted Thu, 20 October 2005 at 4:05 PM
Click here to get to the render options window. AS
AgentSmith ( ) posted Thu, 20 October 2005 at 4:37 PM
This is the difference between normal light and one with soft shadows. Used here was a single radial with soft shadows set to 45. If you use soft shadows, I would suggest you go with not using an increased render setting ("Super"), just leave it at "Regular". As soft shadows AND an increased render setting, even at 4rpp, is asking for a slow render death. AS
UVDan ( ) posted Thu, 20 October 2005 at 7:10 PM
Forum Moderator
AS how did you get such smooth letters?
AgentSmith ( ) posted Thu, 20 October 2005 at 8:47 PM
Yeah, that is thanks to the 16-bit import trick. The letters are a terrain. That terrain is made in Photoshop as a 16-bit Grayscale image. It is saved out of Photoshop as a .tif, that .tif is turned into a .pgm with bikermouses utility he made for us, and in Bryce I go to File>Import, and it imports it as a 3d model, but in Bryce it works just like a terrain. ---------- Any ol' image in the terrain editor will equal 8-bit, which equals 255 levels of gray. 16-bit, Grayscale image have 65,535 levels of gray. (WAY smoother terrains/lattices) ---------- Normally, I might not go through so much for just text, but if its anything that will be rendered smooth, highly reflective, or as glass, I'll make the terrain as smooth as possible. AS
UVDan ( ) posted Thu, 20 October 2005 at 8:56 PM
Forum Moderator
Thanks. Do you have a link to that pgm utility?
AgentSmith ( ) posted Thu, 20 October 2005 at 9:12 PM
Lemme look here......... AS
AgentSmith ( ) posted Thu, 20 October 2005 at 9:14 PM
Attached Link: Download
Tiffer v0.15b
Ang25 ( ) posted Thu, 20 October 2005 at 9:20 PM
Wish I could understand this whole tiffer thing, lol.
danamo ( ) posted Thu, 20 October 2005 at 9:20 PM
Thanks AS! I really intended to learn to use this before, but somehow got sidetracked.
AgentSmith ( ) posted Thu, 20 October 2005 at 10:50 PM
It's just a converter, tif to pgm. It's pretty "command line", but works well. AS
FranOnTheEdge ( ) posted Fri, 21 October 2005 at 6:03 AM ยท edited Fri, 21 October 2005 at 6:13 AM
in reply to AS back in message #8 - yes, but using soft shadows and changing nothing else I was threatened with a render at over 2 hours yet shinyary2's method threatened over 7 hours for a render...
Message#9,
Oh it's in "Render Options", right, thanks.
Message#16,
Thanks AS, dunno if I could figure out how to use that, but you never know (me not being too up on "command Line" stuff)
Message edited on: 10/21/2005 06:13
Fran's Freestuff
FranOnTheEdge ( ) posted Fri, 21 October 2005 at 6:18 AM
I do have another question on this - could you go back to the top and look at the two smaller liquer glasses? There's something odd going on - on the inside of the glasses from the liquid level and up about a quarter of an inch - if you look closely you can see a silvery area. It looks as if it goes in a band following the line of the liquid, around the glass but only as seen through two layers of the glass. What is that silvery thing? And how can I get rid of it?
Fran's Freestuff
AgentSmith ( ) posted Fri, 21 October 2005 at 11:20 AM
I saw those. Almost like their is a clear plastic 'lid' floating atop the wine itself. I don't know what it is. It could be the lighting hitting them weird, but it looks like its part of the mesh... Where are the glasses from? AS
FranOnTheEdge ( ) posted Sun, 23 October 2005 at 10:50 AM
Um, I made them in Wings3D. I hasten to add that I was following instructions at the time - as closely as I could - so I don;t think I did anything there that I shouldn't have. The only point where things might differ is on making the object for the wine, if you make it as originally I was told to then the wine object's material interferes with the glass material, so you have to move the wine object upwards infinetesimally. I can't show you that first render where the two interfere - cos my power supply has melted and I can't access my laptop until I get a replacement power supply - as I didn't realise what had happened and the battery ran down. Can't find a new power supply here in Oman so it may have to wait until I get back to UK. Mid-Nov. In the meantime I'm using my husband's machine (the power supplies don't match) but I have redownloaded Wings and I did bring B5 out here with me, so I can reinstall that. Um... can I reinstall B5.5c directly from Daz without first installing B5? Or do I need B5 then B5.5 then B5.5c? Lot of questions, sorry.
Fran's Freestuff
AgentSmith ( ) posted Sun, 23 October 2005 at 11:06 AM
You do not need B5.0 installed on your computer before you install B5.5 Isn't the B5.5c just an patch update for B5.5? ------------ "I was told to then the wine object's material interferes with the glass material, so you have to move the wine object upwards infinetesimally". -Yup. It sometimes seems when 2 'glass' objects are just touching one another, you can get some strange light effects on the materials. Usually by going ahead and having the two objects 'collide', you can help correct this. AS
FranOnTheEdge ( ) posted Sun, 23 October 2005 at 4:52 PM
But only one is glass - the other is liquid. I don't understand what you mean by "Collide" is that something you do in Bryce?
Fran's Freestuff
AgentSmith ( ) posted Sun, 23 October 2005 at 5:30 PM
Glass, liquid, its all the same in the DTE, they both have the same properties. I just used the word collide, to try and describe two pieces that are overlapping one another. AS
diolma ( ) posted Sun, 23 October 2005 at 5:43 PM
"It looks as if it goes in a band following the line of the liquid, around the glass but only as seen through two layers of the glass. What is that silvery thing?" Fran, I suspect that that "silvery thing" is just a coincidence between the reflections, refractions and the angle the glasses are being viewed at. If you look carefully at the glass with the red liquid, you'll notice the same thing (although to a lesser degree). Suggested experiment: Try moving the camera upwards a bit and point it down further; see if you still get the same effect....:-)) If you don't then it's a Point-Of-View issue (combined with torturous reflection/refraction issues). If you do then it's something else altogether... (and my theory was wrong). Another experiment might be to change the colour of the rear wall and see if that makes a difference to the "silvery" bits... BTW - neither of the above suggestions are intended to be for anything other than experiments to try to isolate the cause of the problem. OTOH, if either of them work sufficiently to get a better pic.....:-))) Cheers, Diolma
diolma ( ) posted Sun, 23 October 2005 at 5:49 PM
Oooops: X-Post with AS. Yup, "collision" (or whatever the real term is) might also be the cause. With apologies to AS, (I'm just trying to help), what I think he is saying is that if the mesh of the "liquid" intersects (ie, crosses into) the mesh of the glass, then that can cause problems for the renderer.... (Did I get that right, AS??) Cheers, Diolma
AgentSmith ( ) posted Sun, 23 October 2005 at 6:29 PM
Actually, I have found the opposite, lol. If I go booleaning in Bryce, and make a glass bowl (on the left), and then fill in part of that empty space in the bowl with a perfectly sized piece that will be the water, I will (sometimes) get a grain look to the areas where water meets glass. But, (On the right), is the same glass bowl and water, but this time the water object has been made just slightly larger (by 0.10). This makes the water object actually go inside the glass object. This is not how it would be in real life, but it will get rid of that anomaly. In short, in Bryce, in this situation, Bryce can be buggy. It doesn't always happen, but can. AS
AgentSmith ( ) posted Sun, 23 October 2005 at 6:35 PM
But/also, diolma is correct, your problem is "just a coincidence between the reflections, refractions and the angle the glasses are being viewed at". A couple of things I would try if I didn't want to change the camera angle; *Tweak the TIR (total internal reflection) numbers in the Render Options window. *Take the object that is the "wine" liquid, and enlarge it slightly on its X & Z axis (width and depth). You may have to only make it larger by 0.01 units to see a difference. *Try both those things together. AS
FranOnTheEdge ( ) posted Mon, 24 October 2005 at 3:32 AM
I'll go remake the glasses in Wings. Otherwise I could be forever trying to sort this out... hang on...
Fran's Freestuff
shinyary2 ( ) posted Mon, 24 October 2005 at 2:48 PM ยท edited Mon, 24 October 2005 at 2:55 PM
AS-- To reply to something that you said much earlier, I've never had this experience. I've found that it renders soft shadows much, much faster at 4RPP than it does on Regular Antialiasing--probably something to do with the different renderer that Premium uses.
The above image demonstrates this... regular antialiasing took 2 minutes, 31 seconds, whereas Premium at 4RPP took all of 21 seconds. This is why I recommend using Premium at 4RPP for test renders, because then you can see what it will look like with all of the Premium effects as you compose the scene (which to me makes a big difference in what I end up doing, especially so far as radiosity is concerned). Of course, it looks terrible at 4RPP, so for the final render you might want to think about using regular antialasing. Unfortunately, then you can't use the cool effects like radiosity and distance blur. Either way, though, you're looking at a really long render.
Message edited on: 10/24/2005 14:55
shinyary2 ( ) posted Mon, 24 October 2005 at 2:50 PM
Fran-- It makes no sense to me why soft shadows should take less time than a terrain. I've always had soft shadows increase the render times dramatically, while terrains don't increase much at all. I wonder if it has to do with a shortage of RAM? Of course, the ideal solution is a combination of both. =)
FranOnTheEdge ( ) posted Mon, 24 October 2005 at 3:04 PM
I have... sorry 'had' lots of ram. So it can't be that, well, unless Bryce5.5 + soft shadows is meant for people with computers bigger than cray2... Oh I've done the new glasses and their wines, still getting that odd silver ring though - could it maybe be something to do with the material on the wine? What settings would YOU lot use for say... red wine and green Creme de Menthe? (Just to stay consistant)
Fran's Freestuff
AgentSmith ( ) posted Mon, 24 October 2005 at 3:27 PM
shinyary2 - Yup, soft shadows are faster when using the Premium render, with soft shadows enabled, at 4rpp. I didn't catch that part you said about using it for "test renders" earlier, sorry. ;o) AS
