Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
Attached Link: http://peepee-weewee.hypermart.net/tiffy/
If you increase the shadows in bryce... That would hep treminiously I feel and so would if you casted the sun a different way... Be Good manThis is kind of a cheezy way of doing it but it does work. Try putting a light around it or in front of it, and then going into the edit properties and drag the lighting to the left to make it a negative number this will pull light out of the scene. I have used this once or twice and had fairly good luck with it, just play around a little with the positioning. I usually change the light color to a gray or something to dull the color a little. Hope that helps.
Nah man, thats kewl.. Whatever gets the job done, right? It doesn't matter how you get perfection as long as you get it.. Right??? I thought so... So it's not cheezy.. Just different way to get the job done...Heya... been a while since I've been to bryce forum. It seems to me that the texturing of a poser figure in bryce is highly dependant on the sky and ambient light settings. I've never been happy with the way that they come in looking as default. The settings I seem to consistently have the best results with are to place the setting dots in both the diffuse and ambient channels, then using the technique that theFOG described, I run the numerical vales as: Diffuse: 65% Ambient: 45% Specularity: 35-45% [Roughly] Mettalicity: about 5% {Not sure just why, but it seems to help] Reflectivity: .05 - 1.5% Then I do a test render under the sky I'm going to use and go back in and tweak the setings in increments of 1 - 5% untill I'm happy. If I add lights to the scene - I retweak to compensate. That's for skin... For Hair, I use the same settings, but I run 100% specularity, 15% mettalicity, and about 10% reflectivity. Clothes it just depends on what sort of material I'm trying to imulate. A lot of times I cheat and use bryce .mats for the clothing and metal textures. Hope any of this works for you... you can check my galery and see some of the results I've gotten with these settings in various sky/lighting conditions.
"I am a good person now and it feels... well, pretty much the same as I felt before (except that the headaches have gone away now that I'm not wearing control top pantyhose on my head anymore)"
I'm still twiddling with my "Survivor" image and wanted to ask if anyone has discovered any "tried and true" materials settings for a Poser import. I feel that the character is a little too bright and wanted to tone it down some more. The ambiance dial in the materials control doesn't let me do small reductions. Could it also be the sky setting getting in the "way"? Thanks!
