My python page
My ShareCG freebies
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=15125&ViewImage=3#Image
You can also use a light gel to give an effect of light through water effect. Look at the second and third page of quim2001's product...there is a watery effect there, to show you what I mean. (There may be other light sets that do the same thing; this is the one I happen to be familiar with--and one can do one's own). If you're not a purist, you can add the effect in postwork. dreamsosweet has a nice [tutorial](http://www.sweetdreamsdigital.com/WaterTut.html) for Paint Shop Pro, if anyone is interested.Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2233511
The link is to a thread earlier this spring where I was attempting to get an underwater effect for a V3. It includes some info on doing an underwater light using procedural shaders in P5/6.Attached Link: http://www.runtimedna.com/mod/filelib/index.php?section_id=18
I know it is too late, but RuntimeDNA had some caustic light gels for Poser 5 that would work in Poser 6. They are free and someone else might find them of use if they haven't discovered them already. PapaBlueMarlin...did you delete the graphic? I went to look and I got a message that it was removed. :(Attached Link: http://www.runtimedna.com/mod/ophoto/index.php?photoid=1359
here it is over at RDNA..._________________________________________________________
"Surrender to what it is - Let go of what was - Have faith in what will be "
http://www.ranquist.net/tutorial/UwTest.htm
Made this after reading some of bagginsbill posts. The link from the page leads back here to an older forum thread on the subject.
Best Wishes,
Rªnce
I plan on using IBL to creat a water scene with the sea creature freebies from CP. How can I create an underwater appearance in P6? I was thinking of doing depth of field or changing the atmosphere, but I'm not sure if anyone has tried this before.
