This a good candidate for the UV mapping tool in the Carrara VM room. Use the option that is a single square. Using this tool will allow you adjust the way the mesh and map play togethter. Once you start using it, it's pretty self explanitory. However, if you need some more help just post back. Mark
Maybe. However, with the different mapping modes to choose from in the UV editor, you can make texture maps match exactly. If the options in the Carrara mapper tool don't meet your needs, the next step is using UVMapper by Steve Cox. Custom maps give you looks you can't get anywhere else. They also take more work than anything else. :D
