Sat, Nov 23, 8:44 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: texture maps
HopsAndBarley ( ) posted Tue, 15 November 2005 at 6:25 PM · edited Sat, 23 November 2024 at 6:40 PM
Hi folks, I've designed this tiffany-lamp style chandelier. I'm having a little trouble applying my texture map to the half-sphere at the bottom. It gets all stretched out. The red-tinted band at the top (the widest part) of the sphere is actually very thin. When I apply the texture map all three parts (the red, the orangeish and the pale mottled yellow) almost look like they are the same width. I used flat mapping, chose whole object from the drop-down menu, and then the appropirate side to apply it to the shape. In fact it isn't quite a half sphere. It's flat at the bottom and there's a fancy knobbly bit there. Is there something I can do to avoid this stretching texture problem? Thanks, H&B
HopsAndBarley ( ) posted Tue, 15 November 2005 at 6:27 PM
PS: don't look too closely at the lighting. I just slapped in a few spot lights for this quick render. I used the same texture map in the glow channel by the way. Cheers
MarkBremmer ( ) posted Wed, 16 November 2005 at 10:06 AM
This a good candidate for the UV mapping tool in the Carrara VM room. Use the option that is a single square. Using this tool will allow you adjust the way the mesh and map play togethter. Once you start using it, it's pretty self explanitory. However, if you need some more help just post back. Mark
HopsAndBarley ( ) posted Wed, 16 November 2005 at 11:09 AM
I'l give that a try Mark, thanks. But one quick question. Would the texture map work better if the shape was a real half-sphere (as opposed to this truncated cone with round sides, you can't see the flat bottom from the angle of the above render)? Cheers, H&B
MarkBremmer ( ) posted Wed, 16 November 2005 at 11:15 AM
Maybe. However, with the different mapping modes to choose from in the UV editor, you can make texture maps match exactly. If the options in the Carrara mapper tool don't meet your needs, the next step is using UVMapper by Steve Cox. Custom maps give you looks you can't get anywhere else. They also take more work than anything else. :D
