Nice results, but also a bit of a "poly bomb" isn't it? If only Bryce will support displacement mappping in the future. Keeps fingers crossed that its a feature of Bryce 6.
Freaking sweet mini tutorial, thank you!
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Technically, what Bryce creates now used to be called a grayscale-to-height map, and a 1024x1024 terrain is over 2 million polys. Displacement could make the same terrain, but the result would just be a handful of polys. (comparatively) AS
Freestuff | IMDB
Credits | Personal
Site
Way to go!!!!! Fabulous stuff! I wanted some knurling on my last...where was you? ;-)
Keeping fingers crossed that if it IS a feature of Bryce6 - I can afford it...
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
@marfx..get thee to the Wings tutorials here and find dracs' 'spaceship' tut..and a few others there..Wings is really a lot easier than it looks..even I can get results in it..;)
Never thought of doing this, but it makes sense..another point to make, tho, is for best results in Bryce, set the display to 'edge' (vertex, lines, whateveryoucallit), and select the knurls area and set to 'hard'..and the details will be there when you export the object..just a tip..;)
I have just finished viewing it and your right, it does make total sense and I dont know how i missed it. I usually go to the tuts page and maybe not seeing a thumbnail there i skipped it..........shame on me! Thanks again and when i get Bryce finished rendering, i will try Wings out again with added hope! ;)
Smile, your dead a long time :)
@Danamo: You mean this was done in Wings????? AGH!!!!!!
You could use that (shifting alternate edge loops) business to bobble up a flat surface too... couldn't you?
Measure
your mind's height
Put this little gif together to show how to make simple knurled knobs/handles/etc in wings for use in bryce. Note: this should be done after all smoothing and bware, this creates a lot of extra polygons, so save beforehand in case your computer blows up.
An example image made using this technique: ![flashlightmadmax.jpg](http://www.3dfightclub.com/~madmax/uploads/flashlightmadmax.jpg)
