With SP: you need to bend her buttocks as well as her thighs to get her in that position. Adjust the bending angles until the flattening is minimized.
For M3: that's a result of having the based updated, and the body morphs not updated. Or vice-versa. Reset your downloads and reinstall both the M3 base and body morph pack.
I've looked on Daz and there are no updates for the body or head morph packages for Michael 3. I've installed the service release 1.. Should I just roll back to the original M3 Cr2? Do you have a link for the INJ file that helps correct the problem on Steph.. as I have this problem in a lot of poses with her :( Many in fact from pose packs. Thanks for the heklp so far :)
Reset your downloads at DAZ. You can do it yourself, from your account history page. Then re-download both the base and the body morph pack.
The morph nickedshield is talking about was made for V3. Not sure how well it would work for SP.
A lot of pose packs are lousy. Including the ones you pay for. There's always a little bit of flattening at the top of the thigh when you bend the legs like that, but it shouldn't be that bad.
