Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
I'm assuming the units that the falloff uses are equal to the units that you X, Y or Z trans parameters use. Therefore if your light was set with a Z trans of 10 and your subject had a Z trans of 0 and your falloff was set to 10, the light would start to fade at the point that it reaches your figure.
Aw- come-on, that would make it much too easy. The falloff dials are using some value other than the screen distance units used by the translation dials. It works pretty well, you just gotta find the range. I've not played with it enough to explain a relationship between the distance and the value on the dial. I generally set the start and end values the same, and adjust them until the subject pops into ,or out of, the light pattern. From there, you can then back the two values off to create the actual falloff effect range. Here are some values that ought to get you in the ballpark: Oh yeah, because you cannot see the effect until rendered, finding that magic starting point requires a lot of guess&render, tweak&render, nudge&render, etc.
Nance, my method of lighting is more, seat-of-pants style. I just play around with the lights until I get the effect I desire. However, I read your tutorial on soft shadows and have been reading your posts on lighting, and I've figured that if I paid a bit more attention to the details of the lights, I could probably achieve my desired effects using fewer lights...therefor my animations don't take so long to render.
So I've been playing around with distance falloff tonight. And if the units that fall off uses and the units that x/y/z trans uses are not the same...then what am I doing wrong?
I'm not trying to challenge what you said. You obviously have spent more time than I have with this. I'm just wondering what part of this I'm missing.
hmmmm... (render,render,render) Ok, sounds good, but still a couple of seemingly inconsistent results that I could use some help with. First, my previous diagram above was calculated using the Front camera. (I know, bad idea) When you guys mentioned getting predictable results using normal screen units I tried it again and to my surprise, I got different lighting results when the same scene was rendered with the Main camera in approximately the same position. What rendered as lit from the Front camera -- came out unlit from the main camera without any other changes in the scene. The point being that choice of camera may affect lighting results. Ok, just forget the front camera issues for now, its goofy and nobody uses it for real renders anyway. With regard to the values in the DistStart &DistEnd dials being standard Poser screen units, consider the following:
Falloff Occuring at Distance Greater than Dial Setting
DIAG #2: -light at 2.700(z), -front surface of stairs at 1.000(z), -front surface of large box at 0.000(z) -DistStart=0.650, DistEnd =0.950. Expected all objects to be UN-LIGHTED as both DistStart and DistEnd values were less than the distance to the nearest object. Results: ALL LIGHTED???, but clearly working, with falloff starting at about the second stairstep and ending at the front of the box. As stated before, though I can get the results I want, it just does not seem quite as predictable as previous posts suggest. No biggie, but if we suggest that this stuff is simple and predictable we're gonna drive nubies crazy. The fact that using Poser screen units as a basis for the settings on this dial did work in petercat's illustration, appears to be coincidental and cannot be applied, as my second example shows, as a general rule. If they were standard Poser screen units then I should have gotten the above result with the values DStart=1.700 and DEnd=2.700 not DStart=0.650 & DEnd=0.950. Just reporting differing results. Can't explain it. As JK asked: "What part of this am I missing" also? Here's the .pz3 (about 100K) if you want to reproduce these results yo-own-self: Lighting Falloff PZ3.zip -Nance ...still in the dark (BrainFog Start=0.000 BrainFog End=0.001)
ooooooooh... a troublemaker eh? dunno about the focal length, but you wouldn't think so. (runs back to Poser to render same file just posted to make sure) CRIPES! Changed focal length from 110 to 35 and falloff zone moved somewhere else entirely. Question sounded preposterous (why would zooming the camera change the relationship between light and obj) but thats got to be the difference between the results we were getting. I believe you nailed it bloodsong. Thanks Mam! JKeller and Petercat, what length lens were you guys using in your renders? o.t. btw-can't get .zip's to work at stas.net and have to click everything else two or three times. Now even the .jpgs won't load. Grrrrrr! With the recent rash of TOS changes, anyone have current suggestions for freebie webspace still suitable for these forums? Thanks again .....bloodsong. (you realize of course that there is no suitably endearing diminutive form of "bloodsong")
Yup! Looks like using Poser standard units will work in the DistStart&DistStop dials if your camera is set somewhere around 35mm! Longer camera lenses, with the same falloff dial settings, move the affected zone farther from the light. Or, as you zoom the camera out, the falloff zone moves toward from the lightsource. Dollying the camera seems to have no effect. (gonna make that Hitchcock/Spielberg "dolly-zoom" move difficult!)
I was using the Main Camera as it loads default: 38mm.
I suppose if you were going to do the Hitchcock (Spielberg steals the technique and uses it on a closeup and he gets a credit?) dolly-zoom move you would have simply have to animate your fall-off distances relative to the animation of your focal with matching keyframes. That or use another program with more straight forward lighting.
heyas; yes, that's me, a trouble-maker. ironbear said so in one of his reveiws. anyway, yeah, it seems completely bizarre that the light falloff would hav ANYthing to do with the camera focal length. however, since you mentioned discrepancies in using the front camera (a parallel camera) and the main camera (a conical camera)... the thought occurred to me. and, basically, it's no weirder than ik-chained feet moving as you adjust a figure's hands, or the light icons popping around as you render.... and that's okay... i dont particularly care to be called diminutive things. ;) (how about bloodiddlydo? naaah...!)
Has anyone got this to work...? The manual says that you can set the distance where the light starts to falloff and the distance past which there is no light. What are the units of distance..? How far is 1..? I can't figure it out. Can anyone help..? Ian
