Sat, Jan 25, 6:37 AM CST
Subject: Poser 5 - still broken!
LonCray ( ) posted Sat, 10 December 2005 at 6:01 PM · edited Sat, 25 January 2025 at 6:27 AM
Good afternoon all! So my Poser 5 stopped working a while ago - it would load a grey screen, then disappear. I asked about this and the solution seemed to be to reload it. Did that, still didn't work. Then I completely deleted it, reloaded it, and got it to work.... but only with the stock Runtime. When I reloaded my Runtime, it doesn't work anymore. Is there a Runtime size beyond which Poser 5 just doesn't work anymore? I've been blithely collecting stuff for Poser - free and not - and hadn't bothered to actually use the program for awhile - but didn't know it was possible to completely kill it. What do I do next?
grylin ( ) posted Sat, 10 December 2005 at 6:14 PM
do u have all the upates? happened to my p6, so i got uppdates,and it worked again. or maybe its something else? like need of a new graphics card? hope u figure it out. :)p.s. p6 has more capability for more in runtime folder :)
grylin ( ) posted Sat, 10 December 2005 at 6:18 PM
bthw, daz studio is as good as p 5 :)
Meshbox ( ) posted Sat, 10 December 2005 at 7:34 PM
Daz Studio has a price that recommends it, but if you have Poser 4 or higher I dont see any reason to use Daz Studio. For what it does, Daz Studio does it very well. It is a very good viewer for P5 models, and Daz has some very nice models in that format. I can open up a Poser file and take a look at what's inside -- its a viewer for Poser files. When Daz gets around to supporting a file format as elementary to the 3D industry as 3DS, it could be more than a viewer. Best regards, chikako Meshbox Design
Best regards,
chikako
Meshbox Design | 3D Models You Want
SamTherapy ( ) posted Sat, 10 December 2005 at 8:03 PM · edited Sat, 10 December 2005 at 8:04 PM
"bthw, daz studio is as good as p 5 :)"
Right.
Oh, I forgot there is no ROFLMAO icon here.
D|S is good but it's nowhere near as good as P5.
Message edited on: 12/10/2005 20:04
Dizzi ( ) posted Sat, 10 December 2005 at 8:08 PM
"When I reloaded my Runtime" How did you reload your runtime? What did you do?
grylin ( ) posted Sun, 11 December 2005 at 4:02 AM
blablah... i use daz. .and i like it more than p 5. doesnt freeze, i can see all textures of v3 better, and easier for me anways., i think alot of ppl like daz as well as poser. so cmon, dont be rude :(
grylin ( ) posted Sun, 11 December 2005 at 4:08 AM
besides, in daz or p 6 for that matter, i dont need to look for every morph i have for v3. so this could go on and on. but u know, im far too busy to write more . (good luck to u ,LonCray ;) )
byAnton ( ) posted Sun, 11 December 2005 at 4:34 AM
This is the "P-o-s-e-r" FOrum. Seems some people forget that. Even a few mods sometimes.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
randym77 ( ) posted Sun, 11 December 2005 at 6:35 AM
I'm glad you like D|S, but to say it's as good as Poser 5 is ludicrous. When it has a setup room, and dynamic hair and cloth, it might be arguable, but now...forget it.
LonCray, runtime size might be the problem. I have never heard of Poser actually choking on large runtimes, but it sure does slow down. You might consider dividing up your runtime into several smaller ones. And keep them out of the Poser folder. I think you'll find that speeds Poser up a lot.
grylin ( ) posted Sun, 11 December 2005 at 7:16 AM
mhmmm.. thats just my opinion.! gawd.whyyy get p**** off?
randym77 ( ) posted Sun, 11 December 2005 at 7:20 AM
Dude, the only one p**** off is you.
grylin ( ) posted Sun, 11 December 2005 at 7:29 AM
dude?? im no dude. lol.im not p off, just fed up . i just loove to discuss.:D
randym77 ( ) posted Sun, 11 December 2005 at 7:31 AM
Everyone who has responded to you did so politely and calmly. Why be "fed up"?
LonCray ( ) posted Sun, 11 December 2005 at 9:13 AM
Interesting turn this thread has taken. By 'reloading my Runtime', I took the Runtime folder that I'd moved elsewhere when I deleted Poser and moved it back. I have not yet reloaded any updates to Poser - I didn't want to waste my time if something in my Runtime or just the size thereof was crashing it. Before I reloaded, I got a grey screen with the initial Curious Labs splashscreen - now I just get the grey screen with a taskbar on top - no splashscreen - and then it disappears. This happens whether I click Poser.exe OR a .pz3 file. BTW, I have DAZ Studio on my drive as well, but don't know enough about running it to make it work well for me - so it's not an option.
randym77 ( ) posted Sun, 11 December 2005 at 9:17 AM
You might want to apply those updates. Many people found P5 unstable without them, with serious memory issues.
Dizzi ( ) posted Sun, 11 December 2005 at 10:45 AM
Moving the Runtime folder back in might move problems in, too. Try only moving the 'geometries', 'libraries', 'reflection maps' and 'textures' folders from the runtime folder back in.
diolma ( ) posted Sun, 11 December 2005 at 2:57 PM
@LonCray: A suggestion... 1. Re-install Poser (again, completely, from scratch, delete existing Poser and runtime 1st). 2. DON'T copy your existing runtime. Instead, start up Poser, then try to create an alternative runtime pointing to the one you want to use. If it works, then ignore the problem and happily continue on your merry way.. If it doesn't work (Poser crashes or misbehaves in some way), then the problem is with your existing runtime.... (Oh, and if there ARE problems, DON'T save, and try to get back to the default Runtime before exiting). This will, at least, help narrow down the suspect area.. Also... There are some products/freebies available that install into folders with names that contain reserved ".xml" characters. Since Poser saves your library set-up in XML format, these characters can cause the xml parser to fail on startup. Which (depending on what the character is) can cause Poser to fail to load... I'm not an XML expert, so I cannot advise further there.. Cheers, Diolma
JHoagland ( ) posted Mon, 12 December 2005 at 1:17 PM
Um, why are you still using P5? Poser 6 corrects almost all of the glitches in Poser 5 (and adds new features)... and is available for a $99 upgrade. Rather than fight with an old version, you might as well upgrade. :) --John
VanishingPoint... Advanced 3D Modeling Solutions
LonCray ( ) posted Tue, 13 December 2005 at 9:31 AM
Because up until this glitch, it wasn't worth another $99 for what is basically a computer game for me. Were I an actual graphic artist, it would be different.
