Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
So far, my attempts at importing pz3 files into Carrara have failed about half of the time, With Transposer, I end up getting empty figures. They are listed in the list of objects in teh scene but they are simply not there. With the Native import, I get 'missing texture' warnings (which are a pain to go through when Carrara doesn't even remember that I just selected a body texture and asks me 5 times to locate the same texture map). Once the popups are over, I end up with a figure that has lost its pose most of the time. I was impressed with the beta but at this point, this is so unreliable than it is pretty much useless to me.
"With Transposer, I end up getting empty figures. They are listed in the list of objects in teh scene but they are simply not there." try going and setting XYZ all to zero.. I have noticed that it places the figure off into the ozone... but it's there. asto finding the texture maps... I'm guessing you have poser 5 also. a lot of textures that poser 6 uses are still located in the poser 5 folder... bla bla bla.. when you asign poser 6 to carrara it doesn't know to go to toe poser 5 runtime to find stuff,... this is just a guess though but worth trying, take all your textures and stuff from 5 and actually install in 6
Hexagon, Carrara, Sculptris, and recently Sketchup.
Thanks, I will check again for the position of the objects. I have poser 6, with only one runtime.
I am having great luck with importing Poser 6 files both natively and with Transposer. It is working as advertised for me. I'm on a PC. My Poser 6 runtime has been combined with Poser 5 content so I have just the Poser 6 Runtime (enhanced) and the Download Runtime (also P6 SR2 update installed). Eovia is great! I almost thought P6 was a waste. I even uninstalled Poser 5 yesterday.
Goodluck everyone,
Stan
Message edited on: 12/11/2005 14:59
1gb of ram isn't enough for Carrara?
Do these poser issues with hair and transposer issues with dynamic hair mean 'patch time' sometime in the near future?
Will I be likely to face these issues with Poser 5 rather than Poser 6? If Carrara has all the features it seems to have, my reasons for considering an eventual Poser upgrade might not be that valid anymore - unless it makes it more difficult to integrate with other apps.
Message edited on: 12/11/2005 17:34
Truth has no value without backing by unfounded belief.
Renderosity
Gallery
arcady. I think its not just the ram but the amount of free space in the scratch disk. I am fortunate to have some 18GB free in the scratch disk allocation. However,Carr5 does not seem to work at any where near the same quality level with Poser6 stuff as it does with Poser5 stuff . We can but hope that a fix is in the pipeline.
bwtr
I'll have to try rendering the White Queen version of Jessi from the SE version of Poser 6 in the Carrara house on my P3 1GHz 1GB RAM system with Carrara Pro 5.0.1 and see if it crashes.
Well I think the first bookshelf is more interesting, in a Salvador Dali sort of way... yeah, looks like a patch is needed. :) You should send this on to eovia, if you haven't already.
Renderosity
Gallery
Does there seem to be any thread here...Is mac working worse than pc etc...really helpful if you posted specifics.Everyone got p6 patch? I would definitely report to eovia.1gig of ram should not cause this that is for sure. Could a texture path issue be to blame or certain file format? Have you got anymore insight after looking at the textures once they come in?
No need to think outside the box....
Just make it
invisible.
Already reported.....
Poser6 Sr2..WinXP Pro...4G of ram & Nvidia 6800Ultra/on board 256K. P4 3.2GHZ The bookcase worked in C4P :) I saved it out of there as a .car to work in the scene I'm working on. Was Using Poser 6 there as well :) The stockings didn't work in either C4P or C5P.....They are from a package at Daz called Christmas Past. That said...all worked fine in other applications :)
Message edited on: 12/11/2005 22:51
Things seem to be working qiute well with Poser 6 and C5Pro. I have experienced one anomaly, however, using Transposer with the link to the Poser file selected I went back into Poser and made some edits, re-opened my Carrara scene and the textures went nuts on render. I opened the same figure in a new document and all work well again. I really don't expect it to be perfect but a reliable way to import Poser 6 files. It seems to be doing that quite well. I hope Eovia can address the problems some of my forum colleagues are having. Good Luck to all, Stan
I gave it another try last night :
And I get the same problems as reported before.
With Transposer, my character appears completely empty.
I checked position and scale - not a problem. It looks like the object just has no geometry.
With Native import, I didn't go through the whole texture import thing . I gave up after a warning of missing .obj file and the first warning of missing texture.
I guess I will have to wait for the update. For the record, I am running XP, Poser 6 SP2 and I have more RAM than I know what to do with...
Message edited on: 12/12/2005 13:49
Agiel, do you have the correct Poser application path selected in the Transposer import dialog? Also, with native import all you have to do is drive to or do a search to find the missing .obj file and import will find everything else. At least that is the way it worked for me at first. Now I can just import any figure. Carrara needs to know where the geometry is in the runtime or where ever you have it on your computer. Good Luck, Stan
I imported the Winter Queen from Poser 6 SE into Carrara Pro 5.01 and she was standing in the Carrara House beautifully. When I rendered the scene with Ambient Occlusion, her eyes were totally black though. So I thought her eye textures were clobbered like in the old TransPoser 2. But when I shined a bulb on her face, her green eyes were there just fine. No crashes using just imported Poser 6 content.
Are you all using transposer 2.1? It's on the eovia site. Love esther
I aim to update it about once a month. Oh, and it's free!
esther. Trying to load the 2.1 update into C5Pro tells me that C5 is not properly installed!!! (I have reported it) I am having problems with stuff from Poser,even imported as .obj or 3ds either crashing Carrara or coming in with nil size or -------minus size. I am close to expunging Poser6 from the computer, AGAIN, because it may be the cause of all my troubles.
bwtr
CPro 5 already includes the latest version of TransPoser. The download on Eovia's site is for standard C5.
Hi, we are not able to reproduce most of the issues posted on this thread and no one is emailing me to give more details... If you are having issues with the Poser import please email me at charles@eovia.com and we will fix them... The good news is that we fixed several other issues and we will release an update soon. Charles
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=1110876&Start=1&Sectionid=6&filter_genre_id=0&WhatsN
I just posted a quick test import using poser 6 and transposer with carrara 5 final version.... take a look came out pretty good. onlt trouble was the hair and body didn't aligned, I had to re positionHexagon, Carrara, Sculptris, and recently Sketchup.
