Wed, Jan 8, 10:33 PM CST
Subject: Problem with background images
Lakeesha ( ) posted Tue, 13 December 2005 at 9:45 AM ยท edited Wed, 08 January 2025 at 3:23 AM
Heya,
as the topic says I have a problem with my background images. After I prescind from using them by importing them directly, because they became pixelating, I started to use a simple prob square with the image as texture.
A long time it went good but now a problem came up. Rendering a poser 4 image in poser 6 I see black horizontal stripes on the background.
A firefly image causes the problem you can see on the attached image. The background should be yellow.
Could anyone tell me why that happened or what I can do to prevent it?
Thanks for your help,
Jess
Message edited on: 12/13/2005 09:46
EnglishBob ( ) posted Tue, 13 December 2005 at 9:48 AM
Don't use the double sided square prop, since Firefly has trouble with double sided polygons. Use the single sided square and all should be well.
pakled ( ) posted Tue, 13 December 2005 at 10:09 AM
or failing that, try making the background image (file|Import|Background image)the same size as the pic you're doing; that should cut down on pixellation. It works in Version 4, at least..;)
Lakeesha ( ) posted Tue, 13 December 2005 at 10:20 AM
@pakled: that won't work because the wanted image is double size of my monitor :-) but thanks. @bob: thanks very much, it worked perfectly :) The result will be shown in gallery as "june"-part of my calendar soon :)
