Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
For store contact, please email store@renderosity.com. I don't recognise the email address you've been sending to... did you get that from a page on here? I'll have it amended if so... Karen Poser Mod
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Randym77, I'm using version 6.0. Thank you for the tip, but is there anyway to have a workable canvas, prior to rendering, that's higher than wider? I know, it's a stupid question as I can pull the camera view out, I'm just used to Photoshop and controlling the canvas. Karen, yes I did. Give me a couple seconds and I'll try to relocate it on the site.
Nother tip... You can change to any size by unchecking the "Aspect ratio" option. Great for 16:9 (or 19:6) images. :)
You don't. Normal computer and TV images are 4:3, widescreen is 16:9 What you have to do is a little math. Example, the following are 4:3: 640 x 480 1024 x 768 1600 x 1200 and so on... What you have to do is work out which size and formatworks best for you.
Window -> Document Window Size has limits (1265x1009 in P5, no idea where they got those numbers) but you can go to Animation -> Movie Output Settings and set whatever dimensions you want, (uncheck 'constrain aspect ratio') and export one frame with sequence type = image file, you should be able to create an image size that will crash any pc.
I tried to look through other posts before posting this question and couldn't locate an answer. By default the Poser window saves images 9.264" wide and 6.389" high. How do I flip that? So the 9.264" is the height? Also, I've sent emails to the Renderosity store and have yet to receive ANY response, does anyone know why? I sent them to fdteam@renderosity.com Thank you in advance.
