Subject: New Beta Update for Vue 5 Infinite
sirrick ( ) posted Thu, 22 December 2005 at 11:01 AM · edited Tue, 04 February 2025 at 5:52 PM
279687 (5.09)(Beta) is available. Haven't installed it yet so no comments.
sirrick ( ) posted Thu, 22 December 2005 at 12:37 PM
Well, I should have known better, just installed it and nothing but constant crashes whenever I try to load a .vob object. Back to 278365 and all is well.
Xiores ( ) posted Thu, 22 December 2005 at 7:52 PM
I have had no problem whatsoever. In fact memory problems, while not solved, are better.
sirrick ( ) posted Thu, 22 December 2005 at 8:30 PM
I'll give it another shot when I have more time, could be just been a bad install. I couldn't load anything without it crashing........I save the entire "application" folder onto my desktop whenever I upgrade so I can easily revert back if there are problems as I've never had any luck with the uninstall update option.
ShawnDriscoll ( ) posted Fri, 23 December 2005 at 2:08 AM
No problems for me. Software openGL seems much more stable. Hard drive is used less, too.
czarnyrobert ( ) posted Fri, 23 December 2005 at 10:02 AM
Strange - when I worked on this latest version on my christmas scene I have zero crashes - to me it look stable.
LCBoliou ( ) posted Fri, 23 December 2005 at 11:28 AM
I think e-on actually did good on this one -- so far. The efficiency of memory usage seems to be much better, and on a test render of a file I had rendered under the previous build version, raytraced soft shadows seemed to render much faster.
-Timberwolf- ( ) posted Fri, 23 December 2005 at 12:11 PM
Version 5.09 - Build 279874,P42.8Gig512Ram,ATIMobileRadeon9000,Win2KSp4.-----Default scene-default render settings.Strange Render result ,isn't it? I wanted to post it to the e.on Forum but I got an error message when creating my topic.I am waiting for the Carrara5Pro box,I am through with Vue-basta.
sirrick ( ) posted Fri, 23 December 2005 at 12:12 PM
Re-installed it this morning, and all seems well this time. It must have simply been a bad install. So Far, so Good :o)
iloco ( ) posted Fri, 23 December 2005 at 2:50 PM
lol........it came in upside down in my Side View and Front View. :( Whacky isnt it. :)
ïÏøçö
tlaloc321 ( ) posted Fri, 23 December 2005 at 7:24 PM
yeah my 2 cents I just got the update and I must say you all have terrified me over these things - so many horror stories but so far so good and ecosystems are wicked fast to appear on your screen ready to preview - I really like that, all else seems good so far. Good luck to everyone out there.
bruno021 ( ) posted Sun, 25 December 2005 at 11:53 AM
I've just read on e-on's forum that plants variations you created with a previous update don't render! Has anyone encountered this problem? I have made a few plants, wouldn't want to loser them ( not that they are masterpieces, mind you!)
DigReal ( ) posted Sun, 25 December 2005 at 7:10 PM
I was reading that same discussion, so was holding off on this beta. Think I'll give it a test tomorrow, since some of the improvements sound good. If I do install it, I'll test out my own plant variations, and report back.
bruno021 ( ) posted Mon, 26 December 2005 at 8:01 AM
Well, apparently, it's only when you set leaf randomness to -100%, so if this is a parameter you don't use, I guess there are no problems, and the imprvements look good, memery management wise.
DigReal ( ) posted Mon, 26 December 2005 at 6:35 PM
Did install the latest beta, but didn't have time to give it a good workout... sometime this week, I hope. My own plants looked to be okay but didn't try that -100% random thing. Only problem so far are the upside down maps on the alpha planes.... fortunately that's easy to fix.
