Fri, Jan 31, 6:05 AM CST
Subject: Black spots on renders
Cowboyuk ( ) posted Fri, 30 December 2005 at 3:25 PM · edited Fri, 31 January 2025 at 5:54 AM
When I try to render above picture using superior or ultra settings, black dots appear during the render. The picture renders fine while doing test renders in final. I am using the 55.09 beta update (Vue 5 Esprit). Has anyone else used this beta, and if so, have they had this problem, and where they able to resolve it without having to rollback to 55.08? I'm sure I read about this same issue a long time ago, but can't find anything using the search function. The scene was setup using the 'Silent Dawn' atmosphere, I haven't changed any of these settings...
Message edited on: 12/30/2005 15:28
RyanSpaulding ( ) posted Fri, 30 December 2005 at 3:32 PM
Try reimporting your geometry. I had a similar "blue spot" problem that went away after I reimported.
-Ryan Spaulding
 VueRealism.Com
Lyne ( ) posted Fri, 30 December 2005 at 6:24 PM
Ooooo! and I was just told by e-on to go get .09....eeek!
Life Requires Assembly and we all know how THAT goes!
firebolt ( ) posted Sat, 31 December 2005 at 9:44 AM
I had a problem like this with V5 Esprit a while back when my system got to its edge with a scene. When I finally managed (after some dozen crashes) to render, one element had those. They disappeared after I changed the lighting setup from Radiosity to Global Ambience and adjusted the lights accordingly.
Cowboyuk ( ) posted Sat, 31 December 2005 at 10:24 AM
Thanks firebolt, It seems that the spots only appear when using radiosity, it renders fine with GI...
bruno021 ( ) posted Mon, 02 January 2006 at 12:23 PM
Maybe because your radiosity quality settings were too low? If not, please report to e-on, this is not right, and should be fixed in the next update. I'm trying GR now too.
