Mon, Feb 3, 8:45 PM CST
Subject: How to import Poser 5 hairs in a good way to cinema 4D?
SUNNY6767 ( ) posted Tue, 03 January 2006 at 10:05 AM ยท edited Mon, 03 February 2025 at 5:56 PM
I import a wavefront.obj bodytexures are ok. But the hair is one lump and the poser 5 material isnt useable as a good tex. But there a so many reasons for me, make it a need to import the figure in Cinema. (Thinking know about to update to Poser 6...but this hairy thing must be cleared before..) Looks really ugly. So I hope someone can help with a view tips what to do?
stewer ( ) posted Tue, 03 January 2006 at 10:14 AM
Attached Link: http://www.reiss-studio.com/trade/productview/39/3/
The easiest most reliable solution is probably Body Studio.
Dimension3D ( ) posted Tue, 03 January 2006 at 6:50 PM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=42060
With my plugin CinePoser LT, you can import the lines of Poser 5 hair as splines into Cinema 4D. Then, you can use a Sweep-NURBS to make them polygons for rendering.
Dimension 3D - Poser Tools, Poser Props and Morphs, Cinema 4D Plugins, and more
Renderosity Store / D3D Web Site
nruddock ( ) posted Tue, 03 January 2006 at 7:51 PM
Attached Link: http://www.skinprops.com/frb_main.htm
Riptide by spanki might also be useful.
jelisa ( ) posted Sat, 07 January 2006 at 9:12 PM
Dimension3D, how would you do the sweep nurbs in c4d to convert the splines?
Dimension3D ( ) posted Sat, 07 January 2006 at 10:27 PM
Add a sweep nurbs to your scene. Turn off angle limit of the phong tag. Add a circle spline and use it as first child of the nurbs. Use a very small radius and no intermediate points (to reduce the number of created polygons). Then, add the spline as second child to the sweep nurbs. This may result in many polygons, but makes the spline visible for render.
BTW, when you export from Poser, turn on "show populated" for all dynamic hair, or Poser will export only the guide hair. And you should use a low value for verts per hair to reduce the number of spline points.
