Wed, Feb 26, 5:55 PM CST
Forum Moderators: Wolfenshire
Photoshop F.A.Q (Last Updated: 2025 Feb 18 8:03 am)
Are you up to the challenge??
Subject: Texture Question
Anniebel ( ) posted Mon, 26 December 2005 at 8:51 PM · edited Sun, 23 February 2025 at 4:33 PM
I am new to PS & I was wondering, is there someway of adding a texture to a layer, without changing the colour? For example, I have painted a body colour mostly whitish, but want to add a bit of texture like pores etc, but if I overlay a skin texture, the colour is changed. Any suggestions? Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
archdruid ( ) posted Mon, 26 December 2005 at 9:57 PM · edited Mon, 26 December 2005 at 9:59 PM
One, (of many) thing you might try is to copy the original layer, move it to the top, then "Paint" it with eraser set to 50% or less, that will give you the same colour to start with... harder to see, though, and an exact replica of the underlying layer... onr thing you shouldn't do is to flatten layers instead of "Merge visible"... flattening layers, when you're done worjing on them, tends to"wash them out" somewhat... there are other methods of doing the same thing, and you might take a look at the tut's here... I have noticed more than a few that deal with skin textures... you can specify Photoshop tutorials instead of "all"... . hope this helps. Lou. By the bye, you can completely erase the top layer, and still work with it.
Message edited on: 12/26/2005 21:59
"..... and that was when things got interestiing."
aprilgem ( ) posted Mon, 26 December 2005 at 10:28 PM
What I like to do is fill a new layer with mid-gray and add noise to it, then I set the layer to overlay.
tantarus ( ) posted Tue, 27 December 2005 at 7:01 AM
It would be much easier to answer if you post the printscreen, now I can only guess what you need. Try the color blend mode, it will preserve the color of underlaing layer and leave the texture. Another trick is to use darken or lighten blend modes depends on the contrast of the layer with the texture :) Maybe some of this will help :) Tihomir
Open your mind and share the knowledge!
cryptojoe ( ) posted Tue, 27 December 2005 at 12:56 PM
If you don't know how to make a screenshot, let us know, we'll be glad to help you.
Yank My Doodle, It's a Dandy!
Anniebel ( ) posted Wed, 28 December 2005 at 9:15 PM
I am not sure how doing a screenshot could possible help, as I said, I am just talking about 2 layers. Tantarus, what do you mean by "colour blend mode" - I have colour dodge & colour burn, which do you mean? Thanks
Helen Keller
tantarus ( ) posted Thu, 29 December 2005 at 7:08 AM
Just "Color", its in the last section of blend modes with hue, saturation, and luminosity :) Tihomir
bonestructure ( ) posted Sat, 31 December 2005 at 8:37 AM
Go to layer styles/blend and experiment with the different blend modes.
Talent is God's gift to you. Using it is your gift to God.
Anniebel ( ) posted Sat, 31 December 2005 at 2:30 PM
"Go to layer styles/blend and experiment with the different blend modes" Yes thanks I tried that, but they all change the original colour.
Helen Keller
Thelby ( ) posted Sat, 07 January 2006 at 4:09 PM
Did anybody say; Filters/Textures from the header menu bar. Maybe you have tried this, matbe not!!! Pick what you want or play around with everything in there! Or you can create your own. Find what you want on the web. Run it through Photoshop and save it, as a .PSD file for best results, under the path I have provided you to follow. Your's may be a little different but not much I assure you. After you save, go back to Photoshop and in Filters/Textures/Texturizer, find the little box with the down arrow in it. Click the down arrow and click on 'Load Texture'. Use the 'Look In' menu that comes up and follow the path to the texture you want and apply it,... waa, laa your done!!! P.S. Make sure that your proper layer is active before applying. Play around with the settings in the 'Filter/Tetures' box until you get what you want. Note there probably will be a little color changing because of the re-dispersion of light. Just adjust your layer's color as needed. Hope this helps!?!?!?
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
archdruid ( ) posted Sat, 07 January 2006 at 10:59 PM
This is another example of what I've always said.. no matter who you are there's ALWAYS something to learn... Thanks Thelby, that's an approach I'd never used. Lou.
Anniebel ( ) posted Sun, 08 January 2006 at 12:47 AM
Thanks, I will try this.
Helen Keller
Thelby ( ) posted Sun, 08 January 2006 at 2:18 AM
A couple of little tid bits to add. 1.If you are going to add many textures, brushes, patterns or anything under/in the Presets folder, beware; the more you add to the folder, the slower Photoshop will become. If you notice my .PSDs above you will see that they are a very large file and I do not many in this folder. Just create a new folder somewhere else on your comp. and follow the path to it. 2. If you marquee around an object you can add texture, color, or almost anything else you want without having a new layer to deal with, this is a quicky way add what you want. I commonly use the methode to add Sunbeams to a Photo or piece of art using the Color Burn & Dodge tools, after I Laso the area I want to effect. Shhhhh,.... that's suppose to be a secrete!!!
