Forum Moderators: Staff
I've seen this problem before. But it usually happens because the conforming garment didn't have a neck group. But that usually causes the garment to never conform properly at all. And yours does. There must be something about the neck JP centerpoint location that's causing this to happen. It is very finiky sometimes in that area. Useing the restore function on the tunic figure might make it snap back into position. Have you had anyone else try it? ScottA
OK Doug. I looked at it. And sure enough. The problem is the neck area. The tunic figure uses a trick you might have heard us refer to as a "Phantom" neck or a "dummy" neck. This is the method of not actually having a neck group in the .obj file. But the .cr2 file has a neck listed in it's list of actors. It's a very handy trick to use for various reasons. What I wasn't aware of is that if you save this figure to a .pz3 file. Poser strips out that Phantom neck part. So when you open it again. Poser can't conform it properly because it needs that phantom neck to know how to conform it properly. What needs to be done is the collar in the .obj needs to be named neck. Then the proper neck lines need to be added to the .cr2 file. I did that for you. And will e-mail it back to you with the changes. Bloodsong. I think this answers your question as well. ScottA
ummmm.... but scott... you dont need a neck geometry object for the jp's to be there. because, normally, i have, say, the horseconformer cr2, which is the zeroed out horse. plug in your new obj that has, like hip, abdomen, chest, but no legs, etc. okay, so the cr2 has obj pointers to all the body parts, but the obj doesnt have them in there. that's fine, you save it to the library, poser leaves the body part pieces in, just takes out the geom pointers. that's in the top half. in the bottom half of the cr2, all the jp info and such is still all there. that doesn't get lost. so, theoretically... you shouldn't need to have an actual neck obj to keep the neck jps. unless humans are weird. :)
I think it is possible to not use a neck. I seem to remember trying it a long time ago. And from what I can remember. If the endpoint location of the chest was placed in the proper spot. Then the clothing would conform properly. But If I remember right. It takes a lot of trial and error to find the exact spot to put it so it works. Since saving the figure as a .pz3 file stripped out the dummy neck in the .cr2 file. It was much easier to simply assign the collar to a group called neck. Having a neck group. Weather it be actual geometry. Or a dummy in the cr2. Really simplifies the conforming process with human upper bodies. ScottA
I came, I rendered, I'm still broke.
