I'm sure you are on to something here. Looking through the shadow cam for this light, it sees nothing until I increase the prop scale to 140%, then all of a sudden it sees the prop - but only on render, not in preview. Spotlight shadow cams see the object at all scales, and in preview.
Definitely looks to me like a bug in P6 - I'll report it to e-Frontier.
Thanks for the pointer on this.
Steve
Attached Link: http://www.physicalc-software.com/forum/viewtopic.php?t=20
Infinite lights require much bigger shadow map sizes in order to store the required info. See above link for more info.Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
Have you got Reuse Shadow Maps turned on? If so, remember to clear the old shadow map. Regardless, it sounds like it's more related to the absence of a main figure. Maybe load a figure and position it away from the view of the camera.
Creator
of OctaneRender
for Poser
Blog
Facebook
I've noticed something a little odd with a prop I'm working on. It's a small prop - about the size of a Poser figure's hand, say, but quite detailed. When rendered in my default setup with a single infinite light, it renders completely black, as if it wasn't being lit at all. The strange thing is that if there is a single figure (not another prop) in the scene, even if my prop is nowhere near it and not parented to it, it renders fine.
A little investigation shows that the render is as expected if:
In other words, the problem only occurs if an infinite light is used with depth-mapped shadows (and the depth map size doesn't make any difference). This must be related to a combination of prop size and light shadowing, but I can't explain why. It's nothing to do with reversed normals, I've tried that.
Does anyone know why this happens and if so what to do about it? (Using Poser 6 SR2, the prop is built with Cinema 4D.)
Many thanks,
Steve
Steve
