Sat, Nov 23, 8:06 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2024 Nov 13 3:03 pm)
Subject: sharper images
inonit ( ) posted Wed, 25 January 2006 at 12:10 PM · edited Sat, 23 November 2024 at 7:18 PM
I was wondering if there was a technique in Apophysis that people use to get sharper images> I have seen some really clear renders in image galleries but mine always seem a bit on the fuzzy side. I have tried sharpening in postwork, as well as using the gamma, brightness, etc. but it doesn't seem the same? Any helpful tips? Thanks
Mags61 ( ) posted Wed, 25 January 2006 at 3:03 PM
Have you tried making the triangles just a little bit smaller. If you just do this a really tiny bit you can keep the composition of the flame the same but it does sharpen up the images. Hope this helps.
We don't cease to play because we grow old, we grow old because we cease to play.
tdierikx ( ) posted Wed, 25 January 2006 at 4:23 PM
Attached Link: http://woosie.net/gallery2/index.php
You can also change your filter radius to a smaller number to make the rendered lines finer... I use 0.2 filter radius myself.
I have Apophysis set up with the following Display settings...
Rendering
Quality = 35
Gamma = 4
Brightness = 4
Vibrancy = 1
Oversample = 2
Filter Radius = 0.2
Preview Density
Low = 5
Medium = 10
High = 15
I also render using the internal renderer with the following settings...
Size = 1280x960
Quality = 1000
Filter Radius = 0.2
Oversample = 2
You can see some of my work at the link above - all were created using the above settings in Apo...
T.
Who? Me?
inonit ( ) posted Wed, 25 January 2006 at 8:06 PM
Thanks folks things are looking better already! I browsed the woosie gallery also....amazing work! Thanks again =D
