Tue, Jan 21, 12:03 AM CST
Subject: How do I apply my texture to the model?
bmnb123 ( ) posted Tue, 31 January 2006 at 12:43 PM · edited Mon, 20 January 2025 at 11:58 PM
Hi I am currently using Bryce 5. I have a model jet I made in true space which I saved as 3ds the model imported fine but how do I apply my texture to the model? Thank you for your time! Jason
Quest ( ) posted Tue, 31 January 2006 at 2:56 PM
Bmnb, if your texture is a ready made bitmap it would be brought in as a 2D texture map in the material editor then you need to choose the mapping mode. If your model is more complex then you might have to apply texture coordinates using another software package like Uvmapper. An image of your model might help us determine exactly what it is you need to do.
pakled ( ) posted Tue, 31 January 2006 at 3:45 PM
it depends on how Truespace handles mapping, I s'pose. If there's a way to differentiate the colored areas you want to use, you can name them (or color them), then using Ctrl+Right Mouse click, and you can select the named areas, and apply mats from Bryce into them. If you can do that, that's how I usually wind up doing it.
There's another thing called UVMapper Classic, which you can get for free off the Web. While more involved, you can use more detailed textures (jpgs off the web, for example) to play with the big boys. I don't have the URL for the site, but there's a UVMapper forum, drop by and they'll set you right..;)
Erlik ( ) posted Tue, 31 January 2006 at 4:05 PM
Weirdly enough, it's http://www.uvmapper.com/. :-)
-- erlik
Hawkfyr ( ) posted Tue, 31 January 2006 at 4:21 PM
Try exporting from trueSpace as anthor format (Like.obj) 3DS is not a good format to use for retaining textures IIRC. You will have to load the "Luuv" Plugin in trueSpace as there is no native .obj export ability in trueSpace. Tom
“The fact that no one understands you…Doesn’t make you an artist.”
Hawkfyr ( ) posted Tue, 31 January 2006 at 4:25 PM
Attached Link: http://www.render-lab.com/Luuv_1.htm
Here is a link to a tutorial,with a link to the plugin (that doesn't seem to be working right now for some reason) Remember to create a folder for your ojcect and place the textures in that same folder. Tom
danamo ( ) posted Tue, 31 January 2006 at 5:03 PM
I could be wrong(it happens), but I believe UVMapper Classic only imports models in an .obj format. I'm not sure about UVMapper Pro, but UVDan would know. When I make a model in Wings I always export it as an .obj file for the very reasons Hawkfyr mentioned.
danamo ( ) posted Tue, 31 January 2006 at 5:12 PM
I import the UVmapped model into Bryce where it will appear as a default gray as it has not had the map applied yet.
danamo ( ) posted Tue, 31 January 2006 at 5:21 PM
Make sure the model is grouped and selected and go to the materials lab and hit the "p" button to go to the picture materials editor(Leo). Load your map into the first slot and select white for the second, unless your map is transparent. Then hit the checkmark and if your map fits your model properly it should show on your model.
danamo ( ) posted Tue, 31 January 2006 at 5:26 PM
I made a simple map for this model. I separated the various parts into different object groups by assigning them to different materials in Wings. Now I can have the best of both worlds because I can still use the Map for the hull, but I can also assign Bryce procedurals to any of the other parts(rails, ports, anchors)etc. HTH, Dan
danamo ( ) posted Tue, 31 January 2006 at 5:28 PM
The other end...
Vile ( ) posted Wed, 01 February 2006 at 12:52 AM
Just sit right back and you'll hear a tale... Now see how long that gets stuck in your head!
UVDan ( ) posted Wed, 01 February 2006 at 12:56 AM
Forum Moderator
Attached Link: UV Mapper Forum Tutorials
UV Mapper Classic, and UV Mapper Pro both only handle obj files. Here is a link to the UV Mapper Forum tutorials. Look them over and they should answer some questions about textures. If you can use the plugin for truespace mentioned and get your file into obj format then you will be halfway home to having it textured.
As an alternate to using the plug in, you can import your cob file into Bryce, then export it in obj format so UV Mapper will read it.
