Don't use ANY of the "World" settings for your texture wrapping. (World space, world cubic, etc, etc.) AS
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
You imagination is your only limitation.
Check out Dark Design for freebies for your own artwork.
can you tell me a few things first... I how to bring up the outliner bar.... where to find a tutorial on how to UVmap in wings
Sure thing. Go to the WINDOW menu, it's in between TOOLS and HELP. Click on OUTLINER on the drop down list. There are two materials there by default-"hole" and "default". Left click on the default material to select it, then right click on it and select DUPLICATE from the drop down list. Your duplicate material will be called "default2" until you rename it. Select the "default2" material and right click on it and give it the name of a part or area you want to texture seperately later on. It also helps to give your new material a color so you know that a particular face or part has been correctly assigned. It will be much easier to see. As far as a UV mapping tut- I would do a seach under UV mapping in the Wings forum. HTH Dan
Sorry for the confusion amlan70. The picture I showed is from Wings3D not Bryce. A lot of people here in the Bryce forum also use Wings, so I tried to answer Darkness_02 here. Next time there is a question about Wings, I will ask the person to join me in the Wings forum. There is no true UV mapping mode in Bryce like there is in Wings, but there are several different materials mapping modes that will usually help you to get the material to cover the model the way you want. Don't ever be afraid to ask questions here. The Forum is full of helpful people. Dan
Danamo: Pro! I imported the model into Bryce and tried adding the map as a texture .......There's several 'mapping' choices in Pro...I used 'box'......
Danamo: Thanks for the tip! ;-)
Sitemail - Dark Design
