Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
TemplarGFX
3D Hobbyist since 1996
I use poser native units
TemplarGFX
TemplarGFX
Oooh that's NICE! I am looking forward to the final, finished blend!
One thing: Remember to blur mr. Lambo slightly to fit the overall blur in the photo :o)
PoseWorks. thats an awesome technique! will it still be effected by bump-mapping (to simulate the effect of the ground in the photo?)
TemplarGFX
"never going to work your car looks to expensive, doesn't blend in " LOL, well I think I would take a photo of a lambo in a car park more than I would take a photo of a spare car park-spot! LOL
TemplarGFX
"LOL, well I think I would take a photo of a lambo in a car park more than I would take a photo of a spare car park-spot!LOL" templargfx...Agreed! However, you could try the same techinque using (EG) an antique Rolls-Royce; A road-going steam-engine; (getting more surreal...) a steam locomotive; a whale???? Excellent technique!! Cheers, Diolma
A whale! hahahahaa that'd be soo funny, with like a seat on top, and indicators on the side, and SIDE MIRRORS! HAHHHAHAA Im working on the car ground reflection now, and yes the bump mapping is effecting it, Ill post the result soon!
TemplarGFX
Sorry for ariving late. I think it's great you took mysuggestion to use a real photographic background for your Lamb. renders. I think it's even cooler that you decided to use a photograph with other cars in it, wow, what a challenge! But, I don't think this photo is worth your time. I'm counting on you finding a much better Bkg. to work from. This isn't ameture work, you want something to be proud of when all is said an d done, not just a good blend. Maybe a picture from a Car Show, Concept Expo, maybe even a really nice Lamb. Dealer lot, that you can mask in photohsop to add a great sky, maybe!
Thats part of the point tho LOL. to be able to get the car to look like it was in the photo even though its am amature one with a little bluring and some distortion! more challenging lol. did you see the other image I did? in my gallery? I put 2 cars on a road (pro photo)
TemplarGFX
TemplarGFX
they are grouped into 3 sections :
the top 3 nodes simulates the tarmacs texture.
The marble nodes sumulates the natural tarmac texture
and the spots node simulates those chips you can see in the photo.
The middle 3 nodes simulates the way the surface reflects.
The blender node is controlled by the ray-trace node, what this does is makes the reflection more visible the brighter that part of the reflection is.
The edge blend node simulates angle-to-surface reflection amounts.
the spots node adds a small amount of reflection-amount change (as the ground in the photo is wet, the reflection wont be even)
and lastly the reflect node!
A BIG THANKYOU to PoseWorks for giving me this basic method of rendering reflections. you saved me alot of time later on!
Message edited on: 02/06/2006 18:30
TemplarGFX
TemplarGFX
THanks! I agree, after playing around with the standard one, it just doesnt look as good! (although I do like that it has no wing :P)
TemplarGFX
I wanted to test if this is going to even remotely work (and whether I have the ability to put the images together! well, this is what I came up with!
Not too bad, only took me about 15 minutes to do this. obviously I will spend much more time on the final image!
what do you think? image below, I uploaded the wrong one LOL
Message edited on: 02/06/2006 23:00
TemplarGFX
TemplarGFX
This quick compilation has made me realise how important focus is going to be in the final image, in order for the car to not seem pasted in, the focus is going to have to be set just right. thats my next priority! also, the photo isnt as "colorful" as the render, so I will have to use some saturation modification of the car when I bring it into photoshop for the final compilation!
TemplarGFX
looking even better. A few thoughts: the glass needs to be less transparent - needs to have more reflection on it (I want to say "more fresnel" but I don't know if that exists in P6?!) to lose some of the interior detail; the Astra and the Lexus(?) have quite bright specularity on the lower front - although Mr Lambo has a different shape, the specularity seems far lower and lacks that "washed out" look. the shadow/reflection under the lambo (between it and the Astra) is too small - needs to be quite dark here (to a similar depth and direction as that of the Astra) I'm loving this though!
The shadow under the car is a hard one, the light that casts the shadows matches that of the light from the photo (I used the shadows of the lexus? wing-mirror (look in the first image) to guage direction and strength) I think the thing that puts you off is that the lambo is so low. I will play around with it some more and see what I can come up with! The specular, you are quite correct, the render I used in my quick-test did not have the upped specular. a new image is coming soon!
TemplarGFX
yes you are right, if you look at the render, the lambo reflects a slight red reflection on the side, very faint. I cannot work out a way to get the reflection to reflect dark. because the dark area of the real reflection is actually a lack of reflection of the sky on the wet tarmac, not really a reflection of the car. this will need some work. I think I will have to render the reflection serperately and use some type of post-process to get the desired effect unless someone knows how to simulate this on a transperant plane (or perhaps a totally different way of doing it
TemplarGFX
TemplarGFX
Great work so far. But, I think the scale is off. The Lambo looks too big to me. The car on the Lambo's left (our right) is a Lexus GS, right? Overall Length of Lexus GS is 189.2 inches. The length of the Murcielago is 180.3 inches. In the last post it sure looks like the Lexus is 9 inches SHORTER, not LONGER. You're off by about 9 percent - multiply whatever your current scale is by .91 and it should look about right. This is assuming, of course, the back ends are lined up. It looks about that way to me.
Attached Link: http://j-girl.axisz.jp/photo/tm2003/car/murcielago.jpg
Hey, templargfx, you are making a unique image. I looked at almost 600 photos of that car and only ONE had it parked next to another car. The other car was also a Murcielago. :) The only picture I could find that showed some sense of scale was this one (in the link). The chick in the picture can't be very tall - and yet the roof is no higher than her elbow. That is one low car. I saw another picture with Paris Hilton sitting in the driver seat. She was so low her elbow was resting on the door sill and her legs were straight out.Renderosity forum reply notifications are wonky. If I read a follow-up in a thread, but I don't myself reply, then notifications no longer happen AT ALL on that thread. So if I seem to be ignoring a question, that's why. (Updated September 23, 2019)
hey now there's an idea - Paris' legs sticking straight out of the window... but I digress:) the only way that I'd be looking to fix the dark area would be to... cheat. ie: doctor the background photo to have a dark area before you place the car in. Probably just borrow the dark area from the Lexus - or simply paint it in. But I'm sure that you'll be looking for a technical solution - so good luck:)
I think I have found a technical solution that should need very little actually post-processing at the end of this project. I am not at home at the moment so I cannot show you what I am talking about, but last night (at 2am) I started to get where I wanted to be with the reflections. basically I have plugged in a reflect node into the transperancy and transperancy edge sections of the material, and set the background of the reflection to white (and removed the background image from it) basically what this does is makes the sky reflection area in my last image into 100% transperant (so you can see the astra and its "reflection" but makes the dark area at the side of the lambo (its non-reflection if you could call it that) opaque. Last night I was working on getting my reflection plains materials to as closely match the tarmac that is in the photo, so that the reflections that are quite opaque look like they fit. I am sure that there will still need to be some doctoring, but hopefully this will minimise it to layer-transperancy painting! As for the size of the lambo, I think it is about the right size (I will try making it a little smaller, and see what you guys think). The reason that I think it is the right size is because I used to work for the Sydney Exhibition Centre as a cleaner (LOL) and they had the car show on while I was working there, and lamborghini had a stand with all the different lambo's that they sell including the murcielego. the car is HUGE, low, but HUGE! people seem to think its like a diablo, that car was big, but this one is bigger still! while on the topic of that car show, while I was working there, this guy came in, and BOUGHT the black murcielego right off the floor! now that one rich bastard! The specular that you see in the images so far isnt the final, although the reflection on the lambo will be very different due to its angled shape, i will show you the end result of the specular as I have it so far when I get home! wow, thats looong post!
TemplarGFX
TemplarGFX
For a roadster, the Murcielago is larger than most. But not nearly as big as a mid-size sedan.
A few :) car lengths for reference:
2005 Hummer H2 SUV 203.5
2005 Mercedes-Benz CL-Class CL65 AMG 196.6
2006 Mercedes-Benz CL-Class CL65 AMG Coupe 196.6
2005 Mercedes-Benz CL-Class CL55 AMG Coupe 196.4
2006 Mercedes-Benz CL-Class CL55 AMG Coupe 196.4
2005 Audi A6 193.5
2005 Ferrari 612 Scaglietti 193.0
2005 Ferrari 612 Scaglietti F1 193.0
2005 BMW M5 191.1
2005 BMW 6 Series 645Ci Coupe 190.2
2006 BMW 6 Series 650i Coupe 190.2
2005 BMW M6 190.0
2002 Lexus GS 189.2 <-- the Lexus in the picture
2005 Volvo XC90 SUV 188.9 <-- I own one of these - a 7 passenger SUV smaller than the Lexus!
2000 BMW M5 188.3 inches <------- I own one of these too - it is not big but still 8 inches bigger than the Lambo !!!
2005 Jaguar XK-Series XK8 Coupe 188.0
2005 Jaguar XK-Series XKR Coupe 188.0
2005 Saleen S7 Twin Turbo 188.0
2006 Jaguar XK-Series XK8 Coupe 188.0
2006 Jaguar XK-Series XKR Coupe 188.0
2005 Ford Mustang 188.0
2005 Panoz Esperante GT Coupe 185.9
2005 Panoz Esperante GTLM Coupe 185.9
2006 Panoz Esperante GT Coupe 185.9
2006 Panoz Esperante GTLM Coupe 185.9
2005 Aston Martin DB9 Coupe 185.4
2005 Volkswagon Passat 185.2
2005 Aston Martin V12 Vanquish Coupe 183.7
2005 Aston Martin V12 Vanquish S Coupe 183.7
2005 BMW X5 SAV 183.7
2005 Mercedes-Benz SLR McLaren 183.3
2006 Mercedes-Benz SLR McLaren 183.3
2005 Ford GT Coupe 182.8
2006 Ford GT Coupe 182.8
2005 Mercedes-Benz CLK-Class CLK55 AMG Coupe 182.6
2005 Lamborghini Murcielago Coupe 180.3 <===== not even as big as a Volkswagon Passat
2005 Maserati Coupe Cambiocorsa 178.1
2005 Maserati Coupe GT 178.1
2005 Maserati Gran Sport Coupe 178.1
2005 Ferrari F430 Coupe 177.6
2005 BMW M3 Coupe 176.9
2006 BMW M3 Coupe 176.9
2005 Lamborhini Diablo Roadster 176.4
2005 Panoz Esperante Coupe 176.3
2006 Panoz Esperante Coupe 176.3
2005 Porsche 911 Carrera Base 175.6
2005 Porsche 911 Carrera S 175.6
2006 Porsche 911 Carrera Coupe 175.6
2006 Porsche 911 Carrera S Coupe 175.6
2006 Porsche 911 Carrera 4 Coupe 175.6
2006 Porsche 911 Carrera 4 S Coupe 175.6
2005 Porsche 911 GT3 Coupe 174.6
2005 Porsche 911 Turbo S Coupe 174.6
2005 Acura NSX 3.0 4-Spd AT 174.2
2005 Acura NSX 3.2 6-Spd MT 174.2
2005 Lamborghini Gallardo Coupe 169.3
Ill do several size "tests" and see what you think, maybe Im a midget and the lambo was huge to ME LOL. anyway, Ill do some quick renders and see what comes out looking good, and post them up!
TemplarGFX
Im not at home right now (again!), I will post up the node setup of how I got this to work when I return home. its both simple and complex at the same time LOL
TemplarGFX
One detail you're missing... Look at the roof of the Astra on the left of the picture. There's a reflection of that lattice tower that's in the background. I don't expect I'd see that on the Lambo, but I do expect to see that white lighting post showing a reflection. I think it should be fairly easy to add, just a cylinder primitive in the right place. And matching to the photo would be a useful check on scale and positioning.
TemplarGFX
167 Car Materials for Poser
