I haven't seen Sin City.. so I'm not quite sure what you're looking for.. but a billboard should be easy to make... if you give me a pic...
You justย can'tย put the words "Poserites" and "happy" in the same sentence - didn't you know that? LaurieA
ย Using Poser since 2002. Currently at Version 11.1 - Win 10.
"Awesome thank you!!!! Where can I download the sign?
It is perfect.
Marque"
You can "download" it from the link in post #5.
Just copy the text from the link into a text editor, and save it as "Street Sign.cr2" to a character folder. That's to say save it to:
[path to Poser folder]RuntimeLibrariescharacterSomeFolderStreet Sign.cr2
Or if you want to IM me with your email address I'll post it to you in a zip file.
Message edited on: 02/11/2006 11:29
My street sign was a cr2 (figure), but it's quite easy to make a simple one one as a pp2 (prop), as billisfree said. Try this, from the Edit menu Genral Preferences set the Display Units to "Poser Native Units", then follow these steps: In Poser, load a cylinder (in P5 you'll find it in the Props > Primitives pallet). Scale it to 20%, yScale it to 5200%. Load a Square prop. From the "Window" menu select "Joint Editor", set the first "Center Point" paramiter to -0.050, close the Joint Editor. xTran the square to 0.050, yTran the square to 0.930, xScale the square to 300%, yScale it to 60%. Save the square back to the pallet as "X" (so as not to overwrite the original). yRotate the square 90. Load "X", yTran it to 0.820. From the Object menu, select "Change Parent", use "cyl_1" as the parent, click OK. Now select "square_1", again set the parent to "cyl_1". Sazve a pz3, just to be on the safe side, so you don't loose your work. Now click the "+" in the Props pallet, the "Set Name" dialogue should pop up, click the "Select Subset" button and put an "x" next to these elements: cyl_1 square_1 square_2 Click OK, set a name for the prop, eg "StreetSign", and click OK to save. Open a new document, load "StreetSign" and make sure it's ok, if so you can delete the pz3 you saved. Now all you need to do is make some textures in a paint program to use on the signs.
Got such a great response and so much help with the cross hoping I can get help with this. I may already have a billboard or if there is one for sale that I can get. Something on the lines of Sin City type. And a street sign that I can use both signs in an angle that will allow you to read them one on top of the other. In other words a name on top and a title on the bottom. Can't pay but you will get credit for it if it's used. Thanks again, Marque
