I only know about RSS second hand, so maybe I'm wrong here. One of the things RSS does (again I think) is put in variations procedurally, to create more realistic skin which is rarely smooth and homogeneous. Those gray spots look like overdone freckles. Is there a freckle dial on RSS?
RE: Using P6. Written in post#1 There is are three products Real Skin Shader - Poser 5 or Poser 6 HyperREAL for V3 - Poser 5 Unimesh Realism Kit for Poser 6 I am wondering if RSS acts diferently in Poser 6. Why is there a Unimesh Realism Kit? Cheers DR
"That government is
best which governs the least, because its people discipline
themselves."
Thomas Jefferson
Sorry I'm onto this late. I can repsond to these things quicker if you post on the support forum at http://physicalc-software.com/forum. Anyway - what is it exactly that you are having? I can see a halo round her head, and some spotting? On close-up head shots, lower the fresnel to 0.2 or 0.25 (from 0.3) - that will clear up the small spots. The halo is due to your lighting - there are lots of backlights, which cause that to happen. There are some probs will lots of lights - the primary one being that you can't set shadow up on them all, or the render will take 24hrs, which leads to bad cases of nostril glow, as you are experiencing. Stick with 2-5 lights, and follow the shadow suggestions at http://physicalc-software.com/forum/viewtopic.php?t=20. Use an IBL at 20% intensity as a fill light. Hope that helps.
Creator of PoserPhysics
Creator
of OctaneRender
for Poser
Blog
Facebook
![file_327036.jpg](https://live.cdn.renderosity.com/forum/threads/2582804/file_327036.jpg)
Really ticking me off. For two days on this. I do not know what I am doing wrong. I keep changing the light settings and the results are the same. I dunno if this is a P6 thing. I can not get rid of it. Before using Real Skin Shader.
