Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
also a bug in formulas, ie i can type red=sqrt((axax)+(ayay)+(azaz)); and it works, however if i do this=sqrt((axax)+(ayay)+(azaz)); red=this; then red seems to be always be 0, so guess its a bug a couple threads down has a formula from me seems easy values work, like this=1; red=this; works, but still, should calculate the longer ones
anxcon, I don't work with formulas so am not sure of the proper syntax rules in carrara.There is limited docs also. Is it possible that is the cause of the error w/ long calcs? That the parenthesis used improperly or lack or quotes etc... could be killing the value?
No need to think outside the box....
Just make it
invisible.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2583465
They didn't fix the issue with surface replicated objects generating vector motion blurs when there shouldn't be any -- see linked message.SF to LA: From June 1 to June 7 2007 I will be riding my bicycle 545 miles to help support people living with HIV/AIDS. Please visit my homepage: http://www.aidslifecycle.org/6010
Attached Link: http://backroom.renderosity.com/~carrara/c505bugs/index.html
I sent the link to Eovia. -Kix-Kix
