Thu, Jan 23, 8:49 PM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: Anim8dtoon, msansing
Fractals F.A.Q (Last Updated: 2025 Jan 21 7:59 pm)
Subject: UF mask: help!
Kid_Fisto ( ) posted Sat, 18 March 2006 at 7:49 AM · edited Thu, 23 January 2025 at 8:40 PM
Help! can anyone tell me how to make the black area of a mask mapping in UF Transparent? how do you do that? thanks, craig
mountmous ( ) posted Sat, 18 March 2006 at 8:33 AM
Make the solid colour transparent, I should say. Click on the black bar and set the opacity to 0. If that doesn't do the trick go the outside colouring and set the opacity of the solid color there too at 0. Sometimes the outside colouring has another "color"bar somewhere, so check that as well. And if that's not enough maybe it's in the inside colouring. Anyway: check the solid color for it's opacity. Good luck. Yvonne
tresamie ( ) posted Sat, 18 March 2006 at 5:25 PM
Hi Craig, Maybe you could attach a file with just the layer you are having trouble with so we could see which of several problems are involved. ~Vivian
Fractals will always amaze me!
ulliroyal ( ) posted Sun, 19 March 2006 at 6:12 AM · edited Sun, 19 March 2006 at 6:17 AM
  1. Activate the Mask Layer.
  2. On the gradient window make the opacity part active.
  3. In the upper left corner of UF say Gradient > invert.
Message edited on: 03/19/2006 06:15
Message edited on: 03/19/2006 06:17
Kid_Fisto ( ) posted Sun, 19 March 2006 at 9:05 AM
thanks guys, i worked it out. the solid color needs to be transparent.
