Wed, Nov 27, 10:18 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: looping a poser walk in Carrara....
spinners ( ) posted Sat, 18 March 2006 at 3:50 AM · edited Wed, 27 November 2024 at 7:29 AM
importing low rez versions of animated poser characters in to carrara works (lots of background people are needed)....now i need to loop their walking..... so far as far a i can tell, i have to do the complete walk cycle in poser (which can be up to 12 seconds x 20fps....) isnt there a more sophisticated way?
Jconxtc ( ) posted Sat, 18 March 2006 at 1:22 PM
umm..not that i know of, maby someone smarter than i knows... Are you using carrara 5 or 5 Pro? cuse in pro their might be a real good way using the graphs, but ive never realy played around with that.
spinners ( ) posted Sat, 18 March 2006 at 1:26 PM
using 5 pro whats the idea?
ominousplay ( ) posted Mon, 20 March 2006 at 1:49 PM
Hi, I'm not sure how detailed you are trying to make the walk, but if it is just one foot after the other, arm swing, head bob, hips tilt, then just either: Import just two steps and loop it in Carrara - shouldn't be 12 seconds for two steps. Or, import the poser figure with bones but no animation, make your own 2 step walk, and loop. Good luck, hope this helps. R
Never Give Up!
spinners ( ) posted Mon, 20 March 2006 at 10:34 PM
i need very little detail.....is there a "looping mechanism" in carrara...something automatic. as opposed to repeating the walking motion on the timeline every second? havent go to the "bones" aspect of poser....(still the beginner)
ominousplay ( ) posted Tue, 21 March 2006 at 2:48 PM
not sure about looping, but I do know you can select the key frames for your two step walk and repeat them as many times as you need. I do know of some repeated functions for swinging, spinning, etc. - check it out in browser, motion.. maybe. R
Never Give Up!
ren_mem ( ) posted Wed, 22 March 2006 at 3:51 AM
There are different tweener options also, would any of those help???
No need to think outside the box....
    Just make it invisible.
