Thu, Nov 28, 4:13 PM CST
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
Subject: Water Drop/Splash Photo
coolj001 ( ) posted Tue, 21 March 2006 at 4:17 PM · edited Mon, 25 November 2024 at 12:59 AM
Hello. Last night I tried to make a water splash/water drop photo like some I've seen around here by the likes of Artists Richard, Zacko, and other photographers around here. I ended up with more of a water blob. I set my timer on my tripod mounted camera w/100 mm macro to 2 sec. delay and started pouring water from a drinking bottle into a pot of water while holding a wireless flash in my other hand. lol. There must be a better way to do this. I was hoping someone would be kind enough to explain this to me. Have a good day. Peace/Jeff :-)
L8RDAZE ( ) posted Tue, 21 March 2006 at 6:15 PM
Jeff! Here's a way to practice Fill a bowl or glass Put in sink Put you faucet on a slow drip compose where drop will land SHOOT (take a bit to get the timing down) Btw I did this just a few minutes ago with no tripod Exif data is intact for reference here (used my Canon G6 for this)
L8RDAZE ( ) posted Tue, 21 March 2006 at 6:31 PM
Again it takes practice and timing! Lots of bad shots a few good ones! Here's another
coolj001 ( ) posted Tue, 21 March 2006 at 8:40 PM
Cool...Thanks L8RDAZE. Wow..amazing shots! ahhhh..the drip in the sink technique. I must give this a try. Exif info? I don't see that...can you provide this? did you use your camera's flash? Thanks, -Jeff
gradient ( ) posted Tue, 21 March 2006 at 9:19 PM
Attached Link: http://www.opanda.com
Freeware Exif viewer is available at the link....
In youth, we learn....with age, we understand.
L8RDAZE ( ) posted Tue, 21 March 2006 at 9:27 PM · edited Tue, 21 March 2006 at 9:31 PM
Yes I did use the built in flash Btw!
Hope this helps!
Joe
Message edited on: 03/21/2006 21:31
coolj001 ( ) posted Tue, 21 March 2006 at 9:52 PM
Thanks gradient, I will checkout that Exif viewer...and thanks for that flash info LRDAZE. I appreciate it. I see you did some hand held shots. I want to try some close up macro shots but for that a tripod is almost necessary. I don't think my tripod reaches that high! hmmmm I must build a platform or something.
Zacko ( ) posted Wed, 22 March 2006 at 12:23 AM
Whenever i shoot drops i put my camera in burst mode. Mine can take 3 shots per second. Then i always lock my focus where i predict the drop to splash. I either use the built-in flash or i set up my two 500W lamps...although they have a tendency to get pretty damn hot! Hope this helps even a little. #:O)
How come we say 'It's colder than hell outside' when isn't it realistically always colder than hell since hell is supposed to be fire and brimstone?
____________________
Andreas
Mystic Pic
Punaguy ( ) posted Wed, 22 March 2006 at 12:34 AM
I did my first drop photo about a week ago with advice from Zacko, who has got this wired. I shot mine in the sink also, used a big pot, preferable black inside to keep the glare down. You really must use a tripod and set your ISO pretty high, 800 or more so your shutter speed is at it's fastest. I used a flash which really didn't blow out the highlights. I propped the pot up in the sink using a small stool so I could try and shoot straight across the pot instead of straight down. Then I let the faucet drip at a steady rate, not too fast as it disturbs the water and you won't get nice circles in the water. I locked focus on the impact area, then counted in my head as the water dripped and tried to time it. Instead of blasting away I find that timing it gives me better results and more usable images. Sure, you will get a bunch of crap also, but it's not an exact science this way, just a way to get some shots in. Hope this helps..Dave~
Kana'es Photography
coolj001 ( ) posted Thu, 23 March 2006 at 6:27 PM
What was I thinking. Of course my tripod reached that high! :-) Unfortunatelly I think I have a defective faucet. I took a few hundred shots the other night and still don't have this down. I experimented w/various shutter speeds and ended up setting it to the fastest. I am handholding a wireless flash for light. I should try using a steady light source. I bet my 12v halogen bike light or my big plant grow and show would work....
Zacko ( ) posted Thu, 23 March 2006 at 10:52 PM
Only to show you it can be done without trying so hard. This was taken using the buit in flash. And its being handheld...with one hand even. I held the icicle in one hand and the cam with the other. Shutterspeed was 2000/1 i think and ISO was 50. Taken outside in bright daylight.
Andreas
Mystic Pic
Zacko ( ) posted Thu, 23 March 2006 at 10:55 PM
Oh...i realise now that it doesnt have a falling drop in it....but the original had though...i cloned it out. #:O)
Andreas
Mystic Pic
Punaguy ( ) posted Thu, 23 March 2006 at 11:03 PM
Now your just showing off buddy..Damn that's nice...creative idea and excecution....don't make me try it...of course I don't know where I would get an ice sickle in Hawaii...Very kewl effect! Aloha
Kana'es Photography
Zacko ( ) posted Thu, 23 March 2006 at 11:09 PM
LOL! Consider yourself lucky pal. Its almost april now and we still have -3F in the mornings....UGH! #:o/
Andreas
Mystic Pic
Punaguy ( ) posted Thu, 23 March 2006 at 11:14 PM
-3F?!? Hawaiians start falling over dead at +50! -3 is colder than my refridgerator...Brrrrrr~ Hope it warms up for ya, after all, it's almost April! ~
Kana'es Photography
