Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2025 Feb 23 2:34 pm)
Hmmm, EnglishBob, I kinda think I might like this idea too. Your method I mean. Is there some really good reason to NOT do things this way, I mean, other then the little bit larger file sizes? I have gobs and gobs of HD space, so that doesn't bother me. I'm finally having the time to get back into Poser since I first bought a couple months back and am now rethinking all of my settings and such. Anyway, thanx............md :)
Ok, I initially thought that a .PMD was a PageMaker document; I figured it was the rendered image. However, I was never able to open them so I just chose Export>Image after rendering to save a .PSD. Never really gave the the .PMDs another thought until last night when I loaded a file after moving it to another drive (without the .pmd) and it asked for the missing file. I chose to ignore it, and when the scene came up the facial parameters were not set, and trying to change the parameter dials gave no result (Victoria2, using the Yell dial, for instance); the figure remained unchanged. So am I correct in assuming the .PMD stores parameter dial settings?
