Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 27 7:28 am)
Iberika, as the screen shots above show, you need to make sure both the eyebrows and upper eyebrows, as well as the eyelashes are set to 100% transparency and for the eyelashes, make sure Catharina's eyelash transparency map is showing in the transparency box at the bottom right. She usually includes a separate lash transparency in her collections. I hope this helps. Melanie
I've highlighted the areas of the material editor you need to be concerned about for transparent items. For the eyelashes (for which the image is relevant), you need to apply a transmap. For the eyebrows, you just need to set both transparency settings (max and min) to 100% Catharina's Tomy just uses eyebrows painted on the head texture, if I recall correctly.
Iberika, you're very welcome. Glad to be of help. Morganza, I agree with you, it seems like you shouldn't have to have transparency on the eyebrows, it doesn't really make sense, but you do have to do that. I've had the same problem and applying the transparency to both the eyebrows and the upper eyebrows is the only thing that works. I don't know for sure, but I would almost suspect that both sets of eyebrows are separate meshes from the face. Somebody correct me if I'm wrong, please. Melanie
Attached Link: http://www.renderocity.com
I was now Online for long time but I will to thank you for All that help the user with the problems of the eyelashes and eyebrows. Catharina P.S check my new website! with new stuff in the meber Area.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I bought Catharina Przezak's Tommi texture for the Millenium Man but I have a huge problem: can't put the texture in his eyelashes and eyebrows. Any idea what's wrong? The eyeleshes have a transparency but it doesn't seem to work. The eyebrows have no specific texture, of course, but neither head or body texture work either. Gracias
