Fri, Nov 22, 8:00 PM CST
Subject: Saving Face Expressions/Morphs
Acadia ( ) posted Tue, 04 April 2006 at 8:01 PM · edited Fri, 22 November 2024 at 7:37 PM
I came up with a face morph and expression that I like, how do I save it for a future use?
cplymill ( ) posted Tue, 04 April 2006 at 8:11 PM
I am not sure
Richard T ( ) posted Tue, 04 April 2006 at 9:49 PM
Attached Link: Tute
Just add it to your pose library. The tute (large html page) may help.
Acadia ( ) posted Tue, 04 April 2006 at 10:12 PM · edited Tue, 04 April 2006 at 10:13 PM
Do I have to pick "Sub Sets"? I notice that when I am in the Pose folder trying to save the morphs and I go into the select sub sets area, the entire figure is selected, I only want the face/head morphs saved. What is the "Expression" folder for? Wouldn't the face morph/expression be saved there?
Neyjour ( ) posted Tue, 04 April 2006 at 10:58 PM
Hmmm... good question. I just saved a face morph last night to the Expressions library. I hope that was right! I didn't test it out... I just assumed that's where it should go. 😕
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
Richard T ( ) posted Wed, 05 April 2006 at 2:12 AM
My mistake. That was for Poser 5 which I have now removed from my PC. I think the expressions library is thge way to go. See the Poser Reference Manual PDF Page 104 (document page 90). Havn't tried it (yet).
Adavyss ( ) posted Wed, 05 April 2006 at 5:37 AM
If you don't go to Select Subset, the pose will include the settings of all head morphs: Morphology morphs & Expression morphs. If you want to make a pure Expression pose you can apply to any character of the same type, you have to remove the non-expression morphs in the Select Subset window (otherwise, you'll lose your character morphology settings). If you want to save a pure morphology pose, remove the expression morphs from the list.
Adavyss ( ) posted Wed, 05 April 2006 at 5:46 AM
The "Expression" folder, which used to be called Faces in previous versions, is a folder where the poses saved (fc2 is a pose file like pz2) include only head morphs values. For each Character, you should create at least 2 sub-folder: 1 faces folder dealing with morphology only and 1 expressions folder dealing with expressions only. Hope it helps
Richard T ( ) posted Wed, 05 April 2006 at 3:28 PM
Thanks very much, Adavyss.
