Do I have to pick "Sub Sets"? I notice that when I am in the Pose folder trying to save the morphs and I go into the select sub sets area, the entire figure is selected, I only want the face/head morphs saved. What is the "Expression" folder for? Wouldn't the face morph/expression be saved there?
say." - Ghandi
If you don't go to Select Subset, the pose will include the settings of all head morphs: Morphology morphs & Expression morphs. If you want to make a pure Expression pose you can apply to any character of the same type, you have to remove the non-expression morphs in the Select Subset window (otherwise, you'll lose your character morphology settings). If you want to save a pure morphology pose, remove the expression morphs from the list.
The "Expression" folder, which used to be called Faces in previous versions, is a folder where the poses saved (fc2 is a pose file like pz2) include only head morphs values. For each Character, you should create at least 2 sub-folder: 1 faces folder dealing with morphology only and 1 expressions folder dealing with expressions only. Hope it helps
I came up with a face morph and expression that I like, how do I save it for a future use?
