Hopefully someone can help you. As much as I love AG... i'm not all that versed in it. Love your pussy willows though... they look so real.
Christina -- "Love me but don't tell me so" Lilly
Bart
My Art
Never Give Up!
Thank you, I love to be loved. I use Carrara, and want to use Hex more. But the bear is a Daz model. The seal was modeled in Hex and then finished in Carrara. Everything was set up and rendered in Carrara, with post work in Adobe Photoshop. I decided to add hair to the bear in photoshop, and highlights to the ice. I need to do post work on the bird. The ducks and models look very useful. The materials are from photos, so... they look too real. Thanks for the nice words. R
Never Give Up!
Any ideas (other than using a shader instead of AG) to lower the polygon count and avoid changing the AG to a vertex object? I want to add bones to make changes in shape to the willows.
Unfortunately bones turn everything to a VM object. You can trying turning down the details in Grows (less strands, segments, sides). The other thing you can try is a texture map and then change the strands mapping mode to UV along strand. You might be able to get by with less strands that have a transparent texture on them. Does that help? Regards, Eric Winemiller Digital Carvers Guild Carrara plug-ins
Eric Winemiller
Carrara and LightWave
plug-ins
Never Give Up!
