Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 18 2:45 pm)
It's the tris. They are offset for the rest of the wall segment by the winding order, I believe.
The only fix I've ever found for it is to redo the geometry itself in that area -- remove the tris.
Incidentally, on the rendering time -- it appears you are making use of reflection and refraction as well as ray traced lights.
The best way to speed up the rendering in such a case (for example, when doing test renders) is to change the lights to non raytraced, or, even better, simnply turn off raytracing in the preview.
