Mon, Dec 23, 9:45 PM CST
Subject: polygon problems suggestions
albertdelfosse ( ) posted Wed, 19 April 2006 at 4:32 PM · edited Wed, 18 December 2024 at 9:06 PM
Got a problem with polygons. I can't figure out a way to fix em. Model was made in 3ds max 8 and renders fine in there. As for poser well..... I've tried a bunch of stuff no dice. Render was done with ray trace checked, bounces = 2, min shade = 0, pix samp = 3, max text = 1024, max bucket size = 64, min displacement  = 0, smooth poly checked, post filter = 1, post filter type = box . Also what are good settings for fast poser renders, etc. it took a little over 2 hours to render the above pic. Of course my system could be a facter 1.7ghz celeron with 1 gig of memory.
BARTWORX ( ) posted Wed, 19 April 2006 at 5:58 PM
And what is the problem ?? that it take's a long time for the render ??
Maybe its me but i can make real sence out of it .....
Chris
Not used anymore
Miss Nancy ( ) posted Wed, 19 April 2006 at 6:12 PM
normals forward?
ynsaen ( ) posted Wed, 19 April 2006 at 6:16 PM
It's the tris. They are offset for the rest of the wall segment by the winding order, I believe.
The only fix I've ever found for it is to redo the geometry itself in that area -- remove the tris.
ynsaen ( ) posted Wed, 19 April 2006 at 6:23 PM
Incidentally, on the rendering time -- it appears you are making use of reflection and refraction as well as ray traced lights.
The best way to speed up the rendering in such a case (for example, when doing test renders) is to change the lights to non raytraced, or, even better, simnply turn off raytracing in the preview.
albertdelfosse ( ) posted Wed, 19 April 2006 at 7:14 PM · edited Wed, 19 April 2006 at 7:15 PM
Well I figured out why I have the polygon problem, in part it has to do with the texture I was using.  Very strange. This is after I changed the texture.
albertdelfosse ( ) posted Wed, 19 April 2006 at 7:16 PM · edited Wed, 19 April 2006 at 7:16 PM
This was the texture I was using.
albertdelfosse ( ) posted Wed, 19 April 2006 at 7:17 PM · edited Wed, 19 April 2006 at 7:20 PM
This was the texture after. I had tried checking normals forward in the original texture I used but it made no diff. I guess poser has probs with certain geometries depending on the textures you use. Something I'll have to remember from now on.
