Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
It's a bit hard to transition from AutoCad to Vue. Vue does not use units, so everything it sized by relation. For example, import a figure and place it next to a doorway, then adjust either the building or the figure to set the proper size. If you are importing several items that need to be kept the same size, place them inside of a cube, and then import. Delete the cube in Vue and now your objects will keep their size relationship. Not perfect, but it works...
Rocks are big when created. Just grab one of the handles and size it smaller. There are no settings that will adjust the size of items on import or create.
Eco-systems are only in Vue 5 Infinite.
Hope this helps!
Peggy
LVS - Where Learning is Fun!
Yep... Get even and and upgrade to Infinite!
You could always build a measuring stick/ruler in 3Ds Max (or whatever modeler you use), for example, from a stack of black and white 1 unit cubes, maybe in a 3 axis shape, and import that into Vue. Not very elegant, but maybe some help.
Leave it in your scene as a reference until you're done sizing stuff, then delete it.
Maybe make it into a Vue .vob model and offer it to others.
_jc 'Art Head Start' e-book: Learn digital art skills $19.95
'Art Head Start.com Free chapter, Vue tutorials, models, Web Tutorials Directory.
TIP: there's a female model that comes with Vue, I use her as a standard scaling tool: import items, scale to her, assuming 1.5 metres height. Then save the items, so later on I cna load things at good scaling. Helps a lot
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
Thanks for the support!!!!
now here's another question:
I'm trying to use image based lighting but VUE only comes with one hdr of some kind of plaza. I'm making a scene of a small house in a tropical environment. I'd like to HDR the environment but I can't find an appropiate map. Browsing the program I found other HDRs, including a sky one. But when I try it, my scene gets very dark, like in a cloudy day, not the kind of illumination a beach could have.
I have searched the net all day long for other HDRs but none fits what I need. When I read a post in this forum that you could do your own HDRs from athmospheres or scenes in VUE, I tried making my own from the "hot summer day" atmosphere that comes with VUE ...
but my VUE espirit can't do that, only Infinite can ...
I bought espirit 'cause EON's page says it is best suited for architects (just like me) but It does not cover all my needs .....................
you're saying CG sunlight is actually based on a real thing????
If you right-click on the camera in the objects list and choose 'Edit Object', you'll get a menu of post-processing options, like exposure changes (maybe again only in Vue5i?).
Shame they didn't recommend their most powerful product. What, architects don't need a full power tool? Maybe they though it was too much to learn?
Sorry, since i only have Vue 5i, it would be hard to know how to help you do it in a different version.
I learned HDRI/IBL (but not an expert) by following the tutorial in the Vue manual. Does your manual have a tutorial?
You can look in the 'Backroom' here for tutorials, search the Renderosity 'Tutorials > Offlsite Links list and check my online directory of Vue tutorials at my site. I don't have my own tutorial (yet) on HDRI use. You could also ask on the e-on registered user's forum and at e-on's Cornucopia 3D forum.
I'm new with Vue.
Really, i'm updating from AutoCAD to VUE, you know: autocad very precise with lots of tools versus Vue with only the necessary ones, Vue managing atmospheres, radiosity, HDR, terrains, procedural plants, stones, etc. versus Autocad ... can actually render!
I'm liking VUE. But again, I have problems with the precision I'm used with Autocad.
I can't find an units system inside vue - I mean, how do I know what meassures has an object? I think it is somehow important since radiosity cares about the size of the model to make its calculations - or so I have read it works like that in programs like Lightscape and Artlantis. And i have had problems with units when exporting to other apps like 3dstudio or Sketchup.
I'll make it short:
1- How can I be sure the imported object measures the same that in my original model?
2.- When inserting rocks, it inserts rocks the size of a car! I don't want rocks that big! how do I set the size of the inserted rocks? (the same for plants and objects)
3.- I'm using Vue 5 espirit. When I first entered EON's site, I got amazed with the ecosystem feature - but I can't find ecosystem materials in my VUE copy. "Well -I thought-, not everything comes free in the life. I can learn how to do them". How do I define an ecosystem material or where can I get some?
hope somebody can help me. And sorry for my english, i'm also somehow new to it.
Thanks!
