Thu, Dec 26, 9:41 PM CST
Subject: How to create this Dark Cloud Effect ???
amlan70 ( ) posted Wed, 10 May 2006 at 10:11 PM · edited Thu, 26 December 2024 at 9:36 PM
Recently I got across some dark cloud effect in this gallery and one from a snapshot from the flim "Sleepy Hollows". Now I was wondering if I can produce the same in one of my projects in Bryce  .Can someone help me. I am attaching two pics to relate to my vision. Please help !!!
amlan70 ( ) posted Wed, 10 May 2006 at 10:15 PM
This one is from the film "Sleepy Hollows"...........
amlan70 ( ) posted Wed, 10 May 2006 at 10:18 PM · edited Wed, 10 May 2006 at 10:19 PM
This pic is from some artist at Cgnetworks.com ( u can see his name at the bottom). As I can remember he mentioned that this has been made with 3dMax,After effects & Vray.But cant this effect be reproduced in Bryce ....... ok with at least some post effects with PS ??
aprilgem ( ) posted Wed, 10 May 2006 at 11:07 PM
Looks like the light is BEHIND the clouds, so yes, I think it CAN be reproduced in Bryce. :) Same goes for Photoshop. Just bear in mind that what you're seeing when you see dark clouds are those same clouds' shadows. There is no light reflected on those surfaces because no light can get to them. That's all there is to it. The technique should follow.
Zhann ( ) posted Wed, 10 May 2006 at 11:36 PM
Hey there,
** amlan70 please replace the images with 'links' to the images, (as they are not yours), Renderosity is very strict about copyright, and I don't want you getting in trouble...=)**
Thanks,
Zhann
Bryce Forum Coordinator
Bryce Forum Coordinator....
amlan70 ( ) posted Thu, 11 May 2006 at 12:04 AM
Ok , surely I shd put the links.But how.I canty see any edit tab. Pls reply. Or Zhann U can put that for me ........ Thanks
Zhann ( ) posted Thu, 11 May 2006 at 2:06 AM
amlan70 ( ) posted Thu, 11 May 2006 at 2:36 AM
OK you may see the skies I wanted to show you here . Zhan`s sky isnt the exact one I wanted to show :
Sky & environment  : http://rapidshare.de/files/20164656/Untitled-1_copy.jpg.html
One from  CGnetworks.com by some artist :
http://rapidshare.de/files/20164720/3ds_max__After_Effects__VRay.jpg.html   . ( I removed the pics and gave links as Zhann told me to do )
But cant this effect be reproduced in Bryce ....... ok with at least some post effects with PS ?? Please help !!! Waiting for your reply . Thanks........
electroglyph ( ) posted Thu, 11 May 2006 at 7:37 AM
Pick a nice volumetric cloud setting or one that starts with the clouds set to cast shadows. The Preset sky called "Fall Wedding" comes to mind. Play with the atmosphere settings. Make the ambient shadow color darker. You can crank up the cloud cover a few percent to make more clouds and get the scene darker.
You can also use a negative infinite light at at between 2-5% behind your camera and low to the ground the ground to darken the undersides of the cloud. Remember Negatives reverse everything so if you want a blue cast to the clouds you should pick an orange brown color to use as the negative light. Positioning these will give you deep shadows but still leave shiny whites peeking through.
pidjy ( ) posted Fri, 12 May 2006 at 7:37 AM
Attached Link: Tutorial to paint dramatic skies
I've used a lot that kind of sky, I usually paint it in photoshop and import it in bryce as a 2D image in the background
Here are some skies I've create :
Vortex Sky
Dark sky
Dark sky2
Check the link to read my tut
Cheers
pidjy ( ) posted Fri, 12 May 2006 at 10:45 AM
Another exemple of painted cloud integration
mat painting
This image is taken from a video I'm working on.
amlan70 ( ) posted Fri, 12 May 2006 at 12:45 PM
EXCELLENT , without words to give accolades to your creations PIDJY. Of course that was really the clouds I had been looking for . But sincerely I believe you have seen the pics at the links I have given. So how do you suggest I shd get that dark environment all around ?? :O
electroglyph ( ) posted Sun, 14 May 2006 at 7:43 AM · edited Sun, 14 May 2006 at 7:44 AM
Clicking on the bottom triangle along the left side of the Bryce desktop brings up a menu that contains Gamma Correction. Make sure this is not checked. If it is every time you do something to darken the scene this control shifts the brightness and contrast back towards normal daylight.
Other than that it's like the Henny Youngman Joke;
How do I get to Carnegie Hall?
Practice - Practice!
