Fri, Nov 22, 10:07 AM CST
Renderosity Forums / Community Center
Welcome to the Community Center Forum
Community Center F.A.Q (Last Updated: 2024 Nov 22 9:21 am)
Forum news, updates, events, etc. Please sitemail any notices or questions for the staff to the Forum Moderators.
Subject: New Site Mail up and ready!!!
  • 1
  • 2
StaceyG ( ) posted Wed, 10 May 2006 at 1:51 PM · edited Fri, 22 November 2024 at 10:04 AM
Attached Link: http://www.renderosity.com/index.ez?viewStory=13047
Messaging system is back up and converted. Please read the info at the attached link
Thanks
iloco ( ) posted Wed, 10 May 2006 at 1:55 PM · edited Wed, 10 May 2006 at 1:58 PM
Mine is showing I have one new message but when I click on it there is none in the inbox. :)
  Is this a glitch that will be fixed.
This is when I am viewing the gallery pages.
  Why is the site so slowwwwwwwwwwwwwww. :(
ïÏøçö
StaceyG ( ) posted Wed, 10 May 2006 at 1:59 PM
That issue is fixed now:)
iloco ( ) posted Wed, 10 May 2006 at 6:35 PM
Thanks for the fix. :)
ïÏøçö
StaceyG ( ) posted Wed, 10 May 2006 at 7:46 PM
No problem:)
SophiaDeer ( ) posted Wed, 10 May 2006 at 9:49 PM
Hi, I am getting the same thing please.
It says I have a message but there is none.
Thanks.
Best,
Nancy
Nancy Deer With Horns
Deer With Horns Native American Indian Site
StaceyG ( ) posted Wed, 10 May 2006 at 9:53 PM
So its still saying you have one message but you've already "read" all and you don't have any new messages? I know it was doing this earlier as I had the same issue but the programmers fixed and now mine is gone so I am making sure I understand correctly so I can report this still ongoing to the programmers.
Thanks
SophiaDeer ( ) posted Wed, 10 May 2006 at 9:58 PM
Yes, I sent myself a memo just to test it. Read and deleted it.
Now it says I have a message when there is none when I go to look.
Thanks.
Jumpstartme2 ( ) posted Thu, 11 May 2006 at 6:17 AM
I just tested as well..everything seems to be working ok here so far...Sophia, just curious what browser you are using?
~Jani
Renderosity Community Admin
StaceyG ( ) posted Thu, 11 May 2006 at 10:18 AM
I have forwarded this thread link to the programmers to take a look Sophia:)
SophiaDeer ( ) posted Thu, 11 May 2006 at 1:15 PM
Thank you very much Stacey.
SophiaDeer ( ) posted Thu, 11 May 2006 at 1:19 PM
Hi Jumpstart,
I am using the MSIE. It seems to be resolved for now. Thank you to all.
Best,
Nancy
romanceworks ( ) posted Thu, 11 May 2006 at 7:29 PM
We also have a message but nothing there. Also, the old method allowed us to click on username of sender and it took us to their homepage ... the new method allows only the reply to the message with no link to the sender. The old method was very useful because we were able to go to senders gallery, store, etc to make comments or look at products when appropriate. It owuld be most helpful if the new method could allow us to link back to the person sending the message. Carol
StaceyG ( ) posted Thu, 11 May 2006 at 8:14 PM
Hi romanceworks,
All the things you mentioned in your post will be just like they were when all the pieces convert and everything is in place. Its just a momentary issue which will be resolved:)
romanceworks ( ) posted Thu, 11 May 2006 at 11:01 PM
Great! Thanks for the info. :o) Carol
iloco ( ) posted Fri, 12 May 2006 at 7:27 AM
For two days I have tryed to send a person a message and in my sent box it shows there are no messages .
  I know this person hasnt received because I have yet to get a reply.
Is this a known issue with new IM system.
ïÏøçö
StaceyG ( ) posted Fri, 12 May 2006 at 9:58 AM
You are sending from the new messaging system correct?  Just making sure it wasn't an email you sent from their member page.
Thanks
iloco ( ) posted Fri, 12 May 2006 at 10:07 AM
Yes I was sending from new message system. :)
ïÏøçö
StaceyG ( ) posted Fri, 12 May 2006 at 10:34 AM
I sent you a site mail message testing things:)  Please see if you have it and reply back so we will know its all working for you like it should.
Thanks
iloco ( ) posted Fri, 12 May 2006 at 4:22 PM
Got it figured out with your help.  Thanks. :)
ïÏøçö
StaceyG ( ) posted Fri, 12 May 2006 at 5:33 PM
So glad:)  Sometimes with change its just a matter of getting used to something different although in this situation because we are in the midst of converting to the PHP things are a little confusing at times. I cannot wait until its all complete and all the pieces are here so that things will flow consistently..
Richardphotos ( ) posted Fri, 12 May 2006 at 9:33 PM · edited Fri, 12 May 2006 at 9:35 PM
it is all well and good but where in the tarnation is the email located? the only way I have found it is when I have had an im. I have looked up and down but do not see a link
Lyne ( ) posted Sat, 13 May 2006 at 2:52 AM · edited Sat, 13 May 2006 at 2:54 AM
I read the new information, looked anxiously at my member options on the side bar, found one that said IM archive...and that was the ONLY link I can see, and used that to get to my message center...where I found all the things I had sent in the past -and posted so unhappily about in the news thread...and of course I deleted them... but ARE THEY GONE?? I mean really gone from your servers, so my privacy is maintained?
So to have privacy, I write a message, send it, and then go delete it from my sent box?
And where/how do I send an IM to someone in a forum thread/posting?? Most forum threads have a IM link near the person's name... I wanted to ask for a IM so I can SEE the new way I am notified, but I can't figure out how to send one to a particular person????
Life Requires Assembly and we all know how THAT goes!
Lyne ( ) posted Sat, 13 May 2006 at 2:58 AM · edited Sat, 13 May 2006 at 3:01 AM
mysql error: You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '???' at line 1, occured in query: "select username from member where userid = ???".
okay...I clicked a persons PROFILE...then I hit THE LINK ON YOUR NEW PAGE to send an instant message, and  I got the above!?
so... would  I be sending an e mail or a message IF I was brave enough to even try with the errors?????????
I tried again...and I was at that person's home page...and I got :
The username entered does not exist.
huh??? is it just that I should not bother till your WHOLE site is done and the pieces are hooked up?? or I have to type the EXACT uesr name in and hope for the best?
AARGGHHHHHHHHHHHHHHHHH!
Jumpstartme2 ( ) posted Sat, 13 May 2006 at 3:10 AM
Here is a screengrab of where the IM/Email is located when you recieve one is, {and where I myself use to link to it...{messaging}
Lyne, try going to the messaging area, then once there, click on 'compose' {if its not already there}
type in your own username {just like it is here, for Im not sure if it is case-sensitive} then send it..then click on the forums page again and you should see a new message where the image I posted is showing it to be.
Let me know if that works :)
~Jani
Jumpstartme2 ( ) posted Sat, 13 May 2006 at 3:33 AM
Another thought..{just to be clear} if you go to a members profile page, the first compose box is for an IM, the lower text box is for emailing.
~Jani
Lyne ( ) posted Sat, 13 May 2006 at 9:15 PM
Thank you, I'll give that a try and keep in mind that the first area is for a message.  I shall go send myself a message! ;)
mejed ( ) posted Sun, 14 May 2006 at 10:38 PM
Please bring back IMs, this new system kinda...well...it kinda sucks. (pardon my english).  IMs were fast, and a lot eaiser to use.
StaceyG ( ) posted Mon, 15 May 2006 at 6:20 PM
Unfortunately the new site mail is here to stay:(  It will work better and quicker once all the pieces are converted over so that you can just click to send someone a site mail instead of having to put type their username in.   Hopefully you will get used to it and it will become easier for you to use.
Sorry but we can't change it back
Thanks
ARTWITHIN ( ) posted Fri, 19 May 2006 at 2:31 PM
I'm getting the same:
Here is what I see on Site Mail when I go to send site mail to someone:
To:
Please note the "To:" field is blank.  This indicates to me that it is addressed to no one.  I have to manually enter the user name.
Others must be getting the same thing as I am getting nothing but e-mails from people trying to contact me.  No site mail is being used to contact me.
I will have to contact everyone to inform them that I now have their real names and e-mail addresses, and let them know they have to manually enter the username if they want to use Site Mail.
The Site Mail worked until the last 7 days.  If you have any further suggestions or comforting words, I would appreciate them at this point.
“Music is harmony, harmony is perfection, perfection is our dream, and our dream is heaven”
Henri Frederic Amiel
StaceyG ( ) posted Fri, 19 May 2006 at 2:35 PM
I'm not sure what you are saying her Artwithin..When you type someone's username in to send them a site mail you are getting the error message above?  I sent you a test site mail to see if I got an error and I didn't
I may be misunderstanding what you are explaining above, if I am I apologize but could you give me some more details?
Thanks
StaceyG ( ) posted Fri, 19 May 2006 at 2:42 PM
I sent you a few site mails using various methods and one showing the Send site mail button. Is this what you are using that gives you the error mentioned above?
Thanks
ARTWITHIN ( ) posted Fri, 19 May 2006 at 2:46 PM
Sorry Stacey, I'm on dial up and there are now so many different steps to getting somewhere that it takes me some time to get back to you.
I got the 3 Stie mails.  I saw the button, and that is the one I use that is giving me the error message.
ARTWITHIN ( ) posted Fri, 19 May 2006 at 2:47 PM
Here are my steps:
I click "Contact", then the "Site Mail" bar, on the "Compose Mail" screen I see the above "mysql error" message and a blank "To: " field.  I have to enter the contact username manually to send the site mail.
StaceyG ( ) posted Fri, 19 May 2006 at 2:51 PM
Getting with the programmers to see why this is may be happening to some.
Thanks
ARTWITHIN ( ) posted Fri, 19 May 2006 at 2:57 PM
Thank you Stacey.  I work at night so I have to go to bed now.  I will reply to any ebots or Site Mail when I get home from work.
tutone1234 ( ) posted Fri, 19 May 2006 at 4:24 PM
Hi Artwithin - I'm assuming you are referring to mailing a member from their homepage.   This problem has been corrected.  Thanks.
Tommy
StaceyG ( ) posted Fri, 19 May 2006 at 5:57 PM
Thanks Tommy:)  Appreciate you taking care of this so quickly!!  You rock it man:)
L8RDAZE ( ) posted Tue, 23 May 2006 at 3:13 PM
Just an FYI...I just attempted to Use Site Mail to Contact Member and received the same error mentioned.  (btw I'm using Firefox)
StaceyG ( ) posted Tue, 23 May 2006 at 8:03 PM
Okay great thanks for letting me know. I will inform the programmers so that can see why this might still be happening for some. Can you let me know if you clicked to send the site mail from the homepage, from the profile here under the avatars, from the Messgaing link at the top, or exactly which path you took, LOL.. It will just help the programmers better isolate the issue.
Thanks again!!
marzo ( ) posted Wed, 24 May 2006 at 4:04 AM
Hi Stacey, I am having this problem too. To try and clarify, I click on a user name in the comments under one of my images; click on 'Use site mail to contact member' and get
above a blank 'To:' box. I'm using IE6, WinXPsp2.
And as you can see, I'm also getting double lines when hitting .
Hope this helps.
How I bled when they said that the rose had no thorns
L8RDAZE ( ) posted Wed, 24 May 2006 at 5:21 AM
It happens when I use the contact link under a gallery image and then use the Use Site Mail to Contact Member.  I noticed it doesn't  automatically insert the members name using this method.  Must be an issue pulling from the database.
please note it does work when using a member's  profile link  from a forum post. (Under the avatar image)
StaceyG ( ) posted Wed, 24 May 2006 at 9:47 AM
Thanks to you all for the info!! Have contacted the programmer for a resolution..
StaceyG ( ) posted Wed, 24 May 2006 at 10:59 AM
Just out of curiousity, did both of you try this yesterday late or today?  The programmer and I both went through the path that you two describe above and it did populate the name and neither of us received the SQL error.  Tommy fixed something earlier yesterday I believe is when it was so that is why I'm making sure you both tried this "after" the fix.. Please let me know so we can continue trying to figure this one out:)
tutone1234 ( ) posted Wed, 24 May 2006 at 1:41 PM
L8RDAZE,
Can you tell me exactly which member you were trying to message.  I'm having a hard time replicating the error so that I can fix it.
I've sent test messages using all of the methods described above and can't seem to produce the error that has been reported.
Thanks.
BAR-CODE ( ) posted Wed, 24 May 2006 at 2:44 PM
HEY thats what i got just now  my old friend the SERVER ERROR....
I can't use the new IM mail system at all i only get these errors and when i try to sent a IM " i get kicked in the but " and got to reload from the start at the site.
Also i miss 80% of the NEW trheads at the forums of my choice and i have to got to the site to check for new topics ...
I posted this more thatn one time in several forums but don't realy get an answer...
Remeber me saying "its like talking to a door" .... well here is the door again...
Greetz Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
-Wolfie- ( ) posted Wed, 24 May 2006 at 2:50 PM
It seems to be down again, or the trial RO was using is expired...
http://market.renderosity.com/mod/sitemail/ - I am getting this:
**Your free trial for the 'sitemail' module has expired.
If you have already purchased a license, please click the button below to activate the module for this site.
No record of completed purchase for 'sitemail' module on this site.
**If you would like to purchase this module for this site, click the "Buy It Now" button below. Be sure to Activate after your purchase.
**~Wolfie~
Helping everyone is the most rewarding failure you'll ever experience.
    - Ray Augé (~Wolfie~'s hubby)
Anything is more stable than Windows . . .
--- Even a relationship based purely on sex!
    - Pam Augé (~Wolfie~)
No meat was harmed during the making of this TV dinner.
L8RDAZE ( ) posted Wed, 24 May 2006 at 7:55 PM
**@tutone1234
**I tried random members...again from the contact link under an image in the gallery.....same SQL error as stated above!
marzo ( ) posted Thu, 25 May 2006 at 3:18 AM · edited Thu, 25 May 2006 at 3:18 AM
Hi Stacey/Tutone,
Just tried again this morning (3.05 CST) exactly as described in my post above and it is just the same. In this instance I was posting to ScrumpyJack. He is a friend of mine and you can 'test message' him if you wish.
Good luck!
Graeme.
AprilYSH ( ) posted Thu, 25 May 2006 at 3:31 AM · edited Thu, 25 May 2006 at 3:31 AM
Got a new problem Stacey...
I sent a message, then before it is read I deleted it. The person still received it.  What's with that?
I deleted it because it had incorrect info. I wrote a new message, but the old one still got delivered, plus the new one.
If it allows deletion of unread messages, it shouldn't allow them to be read.
[ Store | Freebies | Profile ]
a sweet disorder in the dress kindles in clothes a wantoness,
do more bewitch me than when art is too precise in every part
Jumpstartme2 ( ) posted Thu, 25 May 2006 at 6:22 AM
Ive never known a sent message to be able to be stopped once its sent..whether or not the person recieving it has read it or not...once its sent, its sent.
I think that feature is more like a 'read receipt' than anything else.
~Jani
  • 1
  • 2
