Fri, Nov 22, 8:18 PM CST
Subject: mouth
mambru ( ) posted Thu, 01 June 2006 at 3:42 AM · edited Fri, 22 November 2024 at 8:14 PM
since I can make to change the parameters of the mouth so that it smiles, teaches the teeth or simply it opens the mouth?   As is that parameter?
ashley9803 ( ) posted Fri, 02 June 2006 at 1:07 AM
I would love to assist you mambru but I think you will need to make your request a bit clearer. You may need to have someone translate your message for you if you don't speak English well.
pleonastic ( ) posted Fri, 02 June 2006 at 2:09 AM
yes, you can.  you need to select the head of the figure first.  then look at the parameter panel -- you will find various morphs there.  exactly what morphs there are depends on the figure, but the poser 5 and 6 people all come with basic head morphs which you can use to make them smile.
i highly recommend reading the manual that came with poser, and to follow the tutorials.  what is your native language?
mambru ( ) posted Fri, 02 June 2006 at 4:00 AM
ok. mi lengua nativa es el español. y queria saber q parametros he de tocar para q pueda habrir la boca de mi modelo y hacerla sonreir enseñar los dientes ect.
Os agradeceria que pudierais contestarme en español.
Miss Nancy ( ) posted Fri, 02 June 2006 at 1:28 PM
Attached Link: http://www.renderosity.com/members.ez?Who=Casette
env un mensaje al casette y podrayudarle mas mejor que los otros. usted debe utilizar el "smile dial", si usted tiene una versi inglesa. tambien utilize los "mouth open" y "mouth closed" paretros.
mambru ( ) posted Sun, 04 June 2006 at 5:56 PM
miss nancy, pasame tu hotmail
Miss Nancy ( ) posted Sun, 04 June 2006 at 7:14 PM
no lo tengo - que ltima! no quieres hablar con casette? el sabe mucho m que yo, en todos las cosas de 3d.
mambru ( ) posted Mon, 05 June 2006 at 5:04 AM
dile a casette q si me quiere pasar su hotmail.
Tambien habla español??
No encuentro los parametros q me dijistes. Pincho en la cabeza y no me salen ninguno de esos parametros, e intento seleccionar solo la boca pero me parece q no se puede.
Me puedes ayudar???
Gracias por adelantado
Miss Nancy ( ) posted Mon, 05 June 2006 at 1:10 PM
casette tiene un grupo en espal (en otro sitio, no puedo discutirlo) y en ese grupo hay unos expertos en "poser". la respuesta a su pregunta implica la "inyecci del morph", y no sexplicar eso en espal. si no encuentras esos morphs, debes cargar esos morphs de un "morph injection file" que sea vendido por "daz".
dolphing ( ) posted Mon, 05 June 2006 at 1:40 PM
pincha 2 veces seguidas en la caveza y salen los parametros  y si asi no salen solo ve a window y alli pincha y en el menu selciona parametros ;y alli encuentras todos los morph de la caveza incluyendo la boca ,seleciona uno .por ejemplo el smail y subelo de numeros haciendo girar esa ruda que ves alli, luego selecciona otros que covinen con este pues las expreciones las haces tu mediente covinaciones de estas.
