Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Are you guys using P6?
Do you have "Use External Morphtargets" turned on? (they're on by default)
Have you moved the PZ3? or deleted/moved the corresponding .PMD file? That is likely the cause of your problems. The solution is to turn External Morphtargets OFF in the settings. They're likely to mess up a lot of other things anyway.
If the .pmds are the problem as ernyoka1 has described above, I think you can get your V3 morphs back by re-injecting the morphs back into V3. Ie., the dial settings will then have something to affect. The reason I'm not sure about this is because I turned off External Binaries quite awhile ago, so I haven't had to deal with this weirdness for a long time.
But fnog9, I'm afraid this solution wouldn't apply to your prop morphs.
HELLO!
Sometimes, after I save a scene, head and prop morphs no longer work on the character in the saved scene. Does anyone else experience this phenomenon? Is there any way to make the morphs work again?
