Tue, Jan 7, 4:37 PM CST
Subject: Dynamic Cloth Room: What's Choreographed Group For?
LostinSpaceman ( ) posted Tue, 27 June 2006 at 7:13 PM · edited Tue, 07 January 2025 at 11:42 AM
Anyone know what Choreographed groups are for in the clioth room? Any good tutorials?
trevorblack ( ) posted Tue, 27 June 2006 at 9:33 PM
nruddock ( ) posted Wed, 28 June 2006 at 1:21 PM
Any vertices in the Choreographed group move as directed by the translation / rotation / scale morph dials only.
They are also affected by magnets.
ISTR that magnet effects are baked in to the simulation, so you need to set magnets to 0.0 to avoid a double feed effect after calculating the simulation.
DefaultGuy ( ) posted Sat, 08 July 2006 at 12:05 PM
A Quick tutorial is to make a simple kite prop:
  1. Use the Hi Res Cloth prop (the flat square) in the Props library
  2. Go to the Cloth room create a new sim for it.
  3. After you clothify it, click on the Use Choreographed button
  4. using the Add vertices - create a 'cross' diagonally from corner to corner (to emulate the cross sticks on a kite
  5. Animate the prop as if it was a kite moving in the sky
  6. Simulate and you will see the results
Hopes this helps,
-Brian
Lawndart ( ) posted Wed, 12 July 2006 at 1:54 PM
Don't forget to add a wind object to blow up into the kite. :)
