Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 9:10 pm)
Actually UV classic will separate and export separately, but it is very tedious.
You should export from Poser the figure section that corresponds to the map you want to make.
You might try Content Paradise since it is an e-frontier product. The P5 Don never gained enough support to motivate anybody to make anything for it.
You are going to need three different maps so you have to use an object for each body part. I don't see whats crazy about that. A head is usually mapped separately from a body because of the level of detail required. If you wanted a head and body on the same map it would have to be 7-8 times larger to maintain the same level of detail. The eyes are mapped separately because they are spherical and inside the body.
There are texture templates for don at the link.
http://www.kuroyumes-developmentzone.com/
But unfortunately the site seems to be down at the moment, they might have had too many people downloading stuff.
Try saving it as a .gif file?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
You don't need to export anything from Poser to make maps. You should always use the original obj's from the geometries folder.
Load the original obj from the geometries folder (or wherever Poser 6 decided to put it), click [ on your keyboard to hide everything and Ctrl+M to show the material box. Select what materials you want to have on your map** and click OK. Go to File|Save Template (or Ctrl+T), and in the options be sure to select Exclude Hidden Facets. This makes sure that the parts you have hidden stay hidden on your map. Repeat this process for each map you need to make.
**On your head map you'd select things like SkinHead, Lips, Lacrimal, etc On your body map you'd select things like SkinLegs, SkinArms, etc.
You forgot to hide first and I forgot to unhide in my original instructions (step 5)
That link is working again, you can get the templates here:
http://www.kuroyumes-developmentzone.com/poser_p5templates.html
Does anyone know where I can find a texture template- or a seam guide- for P5 Don?
