Sat, Feb 1, 5:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: Template Tantrum
mdbruffy ( ) posted Sun, 09 July 2006 at 6:36 AM · edited Fri, 31 January 2025 at 7:30 PM
Does anyone know where I can find a texture template- or a seam guide- for P5 Don?
dbowers22 ( ) posted Sun, 09 July 2006 at 8:02 AM
You could map one of your own from the free version of UV Mapper.
In fact you can make a template from any object file with UV Mapper.
mdbruffy ( ) posted Sun, 09 July 2006 at 9:20 AM
Okay... hadn't thought of that. Usually when I try to export a figure as an obj something goes wrong. I'll try it and see.
mdbruffy ( ) posted Sun, 09 July 2006 at 9:32 AM
This is UV Mapper Classic's idea of a texture map for Don.
JunkoH ( ) posted Sun, 09 July 2006 at 10:22 AM
This P5 figure has three maps - body, head, and eyes.  What you have is all 3 overlaid.  Try exporting the parts for each map separately
mdbruffy ( ) posted Sun, 09 July 2006 at 10:41 AM · edited Sun, 09 July 2006 at 10:41 AM
UV Mapper Classic won't seperate and export seperately. I've tried.
Doesn't a texture map for this figure already exist somewhere???
JunkoH ( ) posted Sun, 09 July 2006 at 11:19 AM
Actually UV classic will separate and export separately, but it is very tedious.
You should export from Poser the figure section that corresponds to the map you want to make.
You might try Content Paradise since it is an e-frontier product.  The P5 Don never gained enough support to motivate anybody to make anything for it.
mdbruffy ( ) posted Sun, 09 July 2006 at 11:23 AM
You mean if I want a map of his body, I have to export his body and make a map for just that?
JunkoH, I don't mean to sound mean- and I hope trhis doesn't sound that way, But that's crazy.
I'll try it, but it sounds crazy.
JunkoH ( ) posted Sun, 09 July 2006 at 11:42 AM
You are going to need three different maps so you have to use an object for each body part.  I don't see whats crazy about that.  A head is usually mapped separately from a body because of the level of detail required.  If you wanted a head and body on the same map it would have to be 7-8 times larger to maintain the same level of detail.  The eyes are mapped separately because they are spherical and inside the body.
xantor ( ) posted Sun, 09 July 2006 at 1:02 PM
There are texture templates for don at the link.
http://www.kuroyumes-developmentzone.com/
But unfortunately the site seems to be down at the moment, they might have had too many people downloading stuff.
mdbruffy ( ) posted Sun, 09 July 2006 at 1:15 PM
I tried it -and it worked. I'll try to post them both here for anyone else who needs them. Thanks!
nruddock ( ) posted Sun, 09 July 2006 at 1:23 PM
UVMapper classic allows you to hide faces, and when exporting a template, to exclude hidden faces.
mdbruffy ( ) posted Sun, 09 July 2006 at 1:26 PM · edited Sun, 09 July 2006 at 1:30 PM
For some reason the system won't take the head template.
I have tried at least six times and the system flat out refues to upload the damn template. I don't understand. It's in jpg format, it's only 800x562, 149kb, but it will NOT upload.
Miss Nancy ( ) posted Sun, 09 July 2006 at 1:32 PM
it's an interesting point about the relative resolutions of head and body maps. they had the same resolution until p4, when the "big-head" versions started appearing on newer models. the downside to the differing resolutions is that the body and head textures can't match fine detail, on close-up.
mdbruffy ( ) posted Sun, 09 July 2006 at 1:41 PM
I've been trying for the last ten minutes to upload the head template.  I click on browse, I click on the file,I click on post reply- and only my text message is posted. If anyone needs the head template, they'll have to contact me via e-mail.
KarenJ ( ) posted Sun, 09 July 2006 at 2:08 PM
Try saving it as a .gif file?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan Shire
mdbruffy ( ) posted Sun, 09 July 2006 at 2:36 PM
Here goes.
mdbruffy ( ) posted Sun, 09 July 2006 at 2:37 PM
Thanks Karen. Don't know why It was giving me so much trouble. I've always uploaded jpg formats before without any problem.
raven ( ) posted Sun, 09 July 2006 at 4:40 PM
I thought the P5 man and woman were compatible with Michael 1/2 and Victoria 1/2 textures apart from the eyes? So couldn't you just use those templates?
mdbruffy ( ) posted Sun, 09 July 2006 at 5:04 PM
I was not aware of that, so I don't know if that would work or not. Then too, do templates exist for them?
raven ( ) posted Sun, 09 July 2006 at 5:11 PM
Yes. Do a search in the Freestuff for SnowSultan and you will find the templates to download.
mdbruffy ( ) posted Sun, 09 July 2006 at 5:23 PM
okay. thanks.
Xena ( ) posted Sun, 09 July 2006 at 5:47 PM
You don't need to export anything from Poser to make maps. You should always use the original obj's from the geometries folder.
Load the original obj from the geometries folder (or wherever Poser 6 decided to put it), click [ on your keyboard to hide everything and Ctrl+M to show the material box. Select what materials you want to have on your map** and click OK. Go to File|Save Template (or Ctrl+T), and in the options be sure to select Exclude Hidden Facets. This makes sure that the parts you have hidden stay hidden on your map. Repeat this process for each map you need to make.
**On your head map you'd select things like SkinHead, Lips, Lacrimal, etc On your body map you'd select things like SkinLegs, SkinArms, etc.
mdbruffy ( ) posted Sun, 09 July 2006 at 6:11 PM
I'd never heard of doing UV Maps that way. Didn't know Poser could do UV Maps.
Miss Nancy ( ) posted Sun, 09 July 2006 at 6:19 PM
xena is referring to uvmapper.
Xena ( ) posted Sun, 09 July 2006 at 6:30 PM
Oops, yeah, forgot to mention that. Sorry ;)
mdbruffy ( ) posted Sun, 09 July 2006 at 6:36 PM
I did that and got the mess I posted earlier in this thread. UV Mapper Classic won't seperate the materials into indiviual maps.
Miss Nancy ( ) posted Sun, 09 July 2006 at 9:25 PM
md, reread junko's message above. uvmapper (freebie) may not be very good compared to other software, but it will do what you want. check in the uvmapper forum for detailed info.
Xena ( ) posted Sun, 09 July 2006 at 9:33 PM
I just downloaded Classic and tried and it does work. Follow what I posted previously.
xantor ( ) posted Sun, 09 July 2006 at 9:39 PM
Mdbruffy, uvmapper doesn`t automatically seperate the materials into the different maps, you have to do as xena said.
mdbruffy ( ) posted Sun, 09 July 2006 at 9:52 PM
I did what Zena posted-load the original geometry folder- yes. go to the material box and check what I wanted in the map- did that,checked skin body.went to file save and in the options checked exclude hidden facets. did that.
 This was the result.
mdbruffy ( ) posted Sun, 09 July 2006 at 9:56 PM
I did as Zena posted. I loaded the original geometry file.  went to the material file and chose the material- skin body and went to save file and in the options box checked eclude hidden facets. This is what I got.
Xena ( ) posted Sun, 09 July 2006 at 10:03 PM · edited Sun, 09 July 2006 at 10:04 PM
  1. Open geometry in UVMapper
  2. Click [ on your keyboard to hide everything
  3. Ctrl+M to open material box
  4. Select materials you want on template and click OK
  5. Click ] on keyboard to unhide slected materials
  6. Go to Ctrl+T and make sure to checkmark Exclude hidden Facets.
  7. Save your template
You forgot to hide first and I forgot to unhide in my original instructions (step 5)
mdbruffy ( ) posted Sun, 09 July 2006 at 10:48 PM
Finally got it. Part of the problem on my end is that I don't use the keyboard for poser or UV Mapper- I use my Wacom tablet and mouse for everything.
 Thanks Zena- and everyone- for putting up with me. Think I'll go on to bed now.
dbowers22 ( ) posted Mon, 10 July 2006 at 3:33 AM
Quote - You could map one of your own from the free version of UV Mapper.
Here is a tutorial from Renderosity that tells how to create templates
using UV Mapper:
http://camelot.renderosity.com/tut.ez?Form.ViewPages=472
xantor ( ) posted Tue, 11 July 2006 at 7:58 AM
That link is working again, you can get the templates here:
http://www.kuroyumes-developmentzone.com/poser_p5templates.html
mdbruffy ( ) posted Tue, 11 July 2006 at 2:31 PM
Thanks. Just downloaded all of them. Never know when you might need a back-up.
