Sounds to me like another Poser memory issue... first check on the basic material tab, and see if the map has been changed in there... Ive seen it sometimes make the change in one and not the other... If that doesnt help, save your project, and restart poser, and open it again...maybe the memory just needs to be flushed...
"If toast
always lands butter-side down, and cats always land on their feet,
what
happens if you strap toast on the back of a cat and drop
it?"
Steven Wright
Sorry, this is completely OT, but since you asked: "If toast
always lands butter-side down, and cats always land on their feet, what
happens if you strap toast on the back of a cat and drop it?"
The answer is you get both perpetual motion and anti-gravity. The problem is that one cat is not enough. The trick is to multiplex cats into cat-toast arrays. Get about 50 in synch and you can run a small turbine. The other problem is feeding them while they spin, because they lose the feet-landing ability if they expire.
Quote - Sorry, this is completely OT, but since you asked: "If toast
happens if you strap toast on the back of a cat and drop it?"The answer is you get both perpetual motion and anti-gravity. The problem is that one cat is not enough. The trick is to multiplex cats into cat-toast arrays. Get about 50 in synch and you can run a small turbine. The other problem is feeding them while they spin, because they lose the feet-landing ability if they expire.
Im thinking if you teach them to eat toast, all you'd have to do is replace the toast slices ... bit like the airforce do with re-fuelling in mid air... It may just be the planets saving grace, as far as exhausting earth's natural resources???? I can see Time magazines cover already... "Kitty Power... the answer to tommotows problems" catchy huh???
"If toast
what
it?"
Steven Wright
Quote - the cat lands on its feet, then immediately rolls on its back in an attempt to rub off the piece of toast.
At which point you have a plate on the floor with beaten eggs and milk mixture..... WALLAH...an automatic French Toast making machine.... patent this and you could have every European Cousine Chef eating out of your hand.... or....ermmm.....off the kitty's back.... either way youd have it made...
"If toast
what
it?"
Steven Wright
hi all!
i'm placing multiple maps/tattoos on my figures torso and am having 2 things hinder me:
1- for whatever reason when i place my 3rd map it doesn't render the map in the image node, it renders a map already in use! how can this be? i see the correct map in the image node but it renders something completly different! ahhhhhhhh! so what's going on here? yes, i've deleted the image node a couple of times and have tried to reload but same thing. help!
2- also, my maps always come in at the same angle, so if i try and reposition the map to a different angle it still shows up in my image node as the same way...how can i move the map to a different angle?
thanks!
