Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
The morphs may be in pmd format, which is Poser 6 only. To make them Poser 5 compatable, turn off external morphs in Poser 6's general preferences and then resave your characters with the morphs in them. This should get the morphs in the character .cr2 file, which you would then be able to use in Poser 5.
Quote - To make morphs P5 compatible, Annie, just open the .pz2 file and change the version to 5 instead of 6. If you need to use shaders, make sure the extension is .mt5 and not .mc6 or .mt6.
Won't work if the morphs are in PMD files.
If this is the case you need MorphExchange from kuroyume0161's FreeStuff -> http://camelot.renderosity.com/freestuff.ez?Form.Contrib=kuroyume0161&Topsectionid=0
Thanks I will look into these options
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
Quote - You might need to uninstall Poser 6 and then reinstall it before applying SR3....If you do reinstall, make sure you apply the SR3 right after that, don't open Poser first.
Thanks Fazzel, but I tried this, but didn't work for me - problem still existed after.
Quote - ...maybe check to see if you have the latest drivers for your graphics card also.
Thanks Tom, no luck with this either.
Ended up uninstalling Poser again, & reinstalling sr2, then issue fixed - I will just forgo the upgrade.
Quote - The morphs may be in pmd format, which is Poser 6 only. To make them Poser 5 compatable, turn off external morphs in Poser 6's general preferences and then resave your characters with the morphs in them. This should get the morphs in the character .cr2 file, which you would then be able to use in Poser 5.
Thanks, rather than editing the file versions, I tried this first & saved a morphed version in P6, than opened in P6 - works fine.
Thanks for all the suggestions & help.
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
Everything is sluggish, like I have no memory - ok I don't have a lot, only 512, but before I could spin a dial without the damn programme locking up.
Weird issues when I add character textures, like the one above - her forehead disappears. It happens with all MAT sets now for this character - no problems before.
Geeze I hate P6, but I cannot use Trekies morphs in P5, so these new issues are making a thoroughly irritating programme, more irritating.
Any help would be appreciated.
Alternatively, why would morphs only be P6 compatible, is there anyway to make them P5 compatible? Then I could go back to using my nice stable, never had a problem P5, instead of this buggy irritating P6.
Thanks
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery My Freebies My Store
