Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:35 am)
By ruffles, do you mean something like pleats? If so, you can only do horizontal type pleats AFAIK.
Also, by layer, if you mean something like a long sleeve shirt under a t-shirt, IE layers of clothing, than you might be able to do it by making each item separately then adding them in Poser, however, I have a feeling that this might give the cloth room fits, since you will most likely have too many clothing collisions.
you could run the pleats through a modeling app to shape them. You could run the main dress through the clothroom, then add and constrain the pleats to collide with the main dress. Export the finished dress with weild checked, same when importing back to poser.
Lululee, you would be able to turn the dress into a conforming one with your own tutorial.
Just some out of the box ideals.
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?forum_id=79&ShowMessage=231441
There is a tool where you can modify the individual garment sections, so it should be possible to do something like a "ruffle." It would take some planning and could only be in certain planes. The tool is in the Designer Room and looks like a ring with balls on it. When you open it, you can select a section and how much influence your moves have on adjacent points. You can make individual items and then combine them in the Garment Manager prior to exporting, so it should be possible to make the ruffle separately from the garment.If you are planning the ruffle at the bottom of the dress, you can expand the very bottom sections of your design so there is plenty of extra material and then perhaps use alternating strips of vertical constraints in the Poser Cloth Room with draping over invisible primitives.
Or you could make the bottom sections a "ruffle" looking material in the Material room after making a cut in VFB so you have a separate piece. (See my tutorial at the attached link for the general idea).
HTH,
I would like to make a dress with a ruffle. Is it possible to make layers or ruffles in Virtual Fashion?
Any suggestions would be helpful.
Cheerio Lululee
