Mon, Jan 27, 4:47 AM CST
Subject: blistering and strange shadows in P5...
amacord ( ) posted Wed, 02 August 2006 at 4:55 AM · edited Sun, 26 January 2025 at 11:09 AM
say, has this problem been solved in poser6?
thx, A.
stewer ( ) posted Wed, 02 August 2006 at 6:15 AM
Can you be more specific? What problem?
amacord ( ) posted Wed, 02 August 2006 at 6:48 AM · edited Wed, 02 August 2006 at 6:49 AM
hi stewer!
the problem with welded vertices...where people usually recommend to split them, you know what i mean? still the same in P6?
Andi
stewer ( ) posted Wed, 02 August 2006 at 7:28 AM
In Poser 6 you can turn of smoothing completely or set a max crease angle on a per-object base.
amacord ( ) posted Wed, 02 August 2006 at 7:54 AM
thx for the quick answer!
would you kindly set up a quick shot of a simple six-facet-box with welded vertices and with this max crease angle set accordingly? please do me that favour.....
bagginsbill ( ) posted Wed, 02 August 2006 at 12:49 PM · edited Wed, 02 August 2006 at 12:50 PM
Here is the Poser box primitive, exported as obj, then imported twice with the "weld identical vertices" option turned on.
Both have smoothing turned on. The upper one has crease angle 100, the lower crease angle was 80. Since the edges are 90 degrees, the lower one is all crease no smoothing, the upper one is all smooth, no crease. Objects with various angles would have various parts smooth or creased as specified.
amacord ( ) posted Thu, 03 August 2006 at 1:43 AM
thanks a lot and big hands, bagginsbill, i owe you a drink....
A.
