Such an interesting thread. I must reply and hope it is of some help.
You can use the particle generator--also see the browser---for the snow.. If you have actual images of snow crystals they can be the objects for the particles for the close ups. ( My imagination boggles at the beautiful effects you could attain)
For the second question, you could create your own "stump" in the Carrara vertex modeller to "match" the tree. (locate it accurately over the tree) then --?-- can you take the tree into the vertex modeller and delete the polygons at the bottom as requred???
Then, because you have two objects, you can do your "falling" to just the one, leaving the other.
Now I just have to try my wild first thoughts out for myself.
And Mark replied first with a similar answer which makes this old bloke verry happy!
bwtr
I would imagine particles could work very well for falling, or blowing snow. A tree-stump, unless it has a lot of roots, is a pretty easy object to model using either the vertex or spline modeler. Converting a tree model from Carrara's plant modeler to a vertex model, (so you can edit the mesh) seems like a lot more work than just using the modelers.
I've edited a tree-generator created mesh at least once. I think I was making some logs for a simple fire. Took a short tree, hacked the remaining branches down to stubs and broke up the top and bottom. It is an okay mesh to work with (the tree generator mesh). Not too bizarre and messy -- and with careful tweaking of settings doesn't have to be too big, either.
Thank you. Now if I could spell "Hexagon" I'd be set. I've tried out Silo recently. The free 30 day download is small to load and seems to be complete. Nice - needs a 3 button mouse to get the full effect. The only thing I had trouble with was exporting the model. It came out rough, even after subdivision in Carrara.
Never Give Up!
Actually if one of you could give me a step by step walkthrough of making snow with the partical generator I would really appreciate it, as I can't get the partical generator to actually do anything, let alone create snow. I really am a newbie. Thank you all so much. Sorry it took so long to reply. David
Bwtr thanks for the pictures. Unfortunately I am still having problems getting the particles to work. If somebody would be kind enough to post a scene with particles working so that I can compare it to my scene to try and figure out what is wrong, I would really really apreciate it.
Sincerely,
David
Hi. Thank you very much for all you posts in earlier posts. They have been very helpful. Two more questions for you. Can Carrara create, simulate falling snow over a wide area and up close? The project I'm working now requires snow falling. Any idea how to create this? My other question. Can the tree lab generate tree stumps. In this one scene the tree is supposed to be cut diagonally and fall over. This is for a series of prints not animation. I have played around with the tree lab a bit, but have come up with know ideas. Is it posible to select the section of the tree you want and to shatter that section? Thanks you for all you time and effort. It is making my transition from Bryce easier, and hopefully I will be able to post some of my work in the near future. Sincerely, David
