Fri, Feb 7, 2:44 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Why is this happening-strange material pattern?
bandolin ( ) posted Thu, 24 August 2006 at 7:09 AM · edited Fri, 07 February 2025 at 2:44 AM
I've had this happen before, but never understood why it happens. Could anyone enlighten me why the floor has this strange pattern?
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
EnglishBob ( ) posted Thu, 24 August 2006 at 7:20 AM
Double sided polygons do that in Poser 5 and 6. Did you use the square prop for the floor? If so, use the single sided square instead.
bandolin ( ) posted Thu, 24 August 2006 at 7:45 AM
Yup, that was it. Thanks a bunch.
<br />
Freestuff</a>
dbowers22 ( ) posted Thu, 24 August 2006 at 11:21 AM
Another thing you could do if you have Poser 6  is go to the material room,
select that item, and at the bottom of the material surface main node
put a check in Normals Forward.  I assume you already deleted your
floor and replaced it, so it's too late to try that.  But this is good if you have
a prop that gives those odd patterns too.
bandolin ( ) posted Thu, 24 August 2006 at 1:19 PM
What do you mean by Material Surface Main Node. I checked an older version of my file that still has the box primitive, and couldn't find you're referring to.
<br />
Freestuff</a>
Porthos ( ) posted Thu, 24 August 2006 at 2:19 PM
> Quote - What do you mean by Material Surface Main Node. I checked an older version of my file that still has the box primitive, and couldn't find you're referring to.
MS Windows 7 Home Premium 64-bit SP1
Intel Core i7-2600 CPU @ 3.40GHz, 12.0GB RAM, AMD Radeon HD 7770
PoserPro 2012 (SR1) - Units: Metres , Corel PSP X4 and PSE 9
